95 ls no start
Old Nov 8, 2011 | 07:48 AM
jmacsss's Avatar
Default 95 ls no start
no check engine light, car was running beautifully, been sitting for 2 years and started right up. last night we thought we heard a little misfire so my boy pulled one of the wires while it was running to see if the cylinder was getting spark, put the wire back in, then the car died. since then he replaced plugs wires cap rotor, fuel pump gets power, car just wont start.
Old Nov 8, 2011 | 11:06 AM
fcm's Avatar
fcm
Old Fart
Default Re: 95 ls no start
Coil or ICM most likely, did you check to see if you have spark? 94
Old Nov 8, 2011 | 01:59 PM
DeeC2's Avatar
10 Year Member
yea when you pulled the plug you blew the coil, just replace your distributor. (thats the easy way to fix it)
Old Nov 8, 2011 | 05:09 PM
fcm's Avatar
fcm
Old Fart
Why the hell would you replace the whole distributor assembly if all that is wrong is a blown coil replace the coil, it's less work and a lot cheaper then a complete distributor, the same goes if it is the ICM. 94
halocore
Jan 8, 2010 04:20 PM
crxion91
Jan 19, 2008 12:35 PM
drtile
Jan 2, 2008 03:17 PM
aznxphreak
Feb 9, 2006 04:43 AM
incognitoracerr
May 6, 2003 03:07 PM
