What is this washer called.
Old Nov 8, 2011 | 07:12 AM
hondad6's Avatar
Default What is this washer called.
Does the washer come with the new harmonic balancer, or do i have to order it separate? Also is there supposed to be one long key pin or are there 2 separate ones.
Story is, i have a 1998 GSR, and after 220000 miles the harmonic balancer bolt worked itself loose. Idk who changed the timing belt last but it is old so it was not mechanic error. The balancer wallowed itself out and is useless. The key in the timing belt sprocket is there, but I'm not sure if it is a separate key or if i need to get a puller. I have looked in a few places but i cannot find a clear answer. Thanks for any help
Old Nov 8, 2011 | 07:27 AM
kyden's Avatar
Default Re: What is this washer called.
the washer is the timing belt guide plate. does not come with the pulley.
Old Nov 8, 2011 | 07:29 AM
hondad6's Avatar
Thanks it is pretty bad too.
Old Nov 8, 2011 | 11:13 AM
fcm's Avatar
fcm
Old Fart
http://www.acuraautomotiveparts.org/...s=&view=normal
What kyden said, it is #16... 94
jaxflex
Feb 24, 2016 02:17 PM
yosuthnmasa
Apr 8, 2008 07:29 AM
Spade
Acura TL, RL & ZDX
Jan 1, 2004 06:26 PM
ebelp
Feb 11, 2002 03:36 AM
