h22a balance shafts
You can search how, but there is removing the belt and there is completely removing them all together. Either way, you have to buy a block off plate and either a spacer or a K series crank pulley and a timing belt guide for a h23.
its very simple, just remove the belt thats it. good for 5whp across the board.
if u want to ditch the shafts themselves you will gain oil psi but u will need a kit as mentioned. its easier to remove them when your rebuilding the motor.
satan_srv
Nov 21, 2002 02:15 PM
BigBank420
Oct 22, 2002 08:22 AM
