brake block question
Old Nov 7, 2011 | 03:55 PM
rpmraper's Avatar
Icon2 brake block question
hey guys its been a while, anyhow i just scooped up a 93 si hatch for a good price, have a couple issues with it i hope maybe you can help me with, 1st is they guy replace the brake block that turns two lines into 4 for the brake lines, im assuming he did not bleed the system correctly because it wont hold pressure and you have to pump it sometimes, would that give me a weird idle somehow? it idles high then drops to normal, then goes high again ( annoying) its not bouncing like a tps idle. also when im at a steady speed i can hear the engine miss slightly could that be because of the high compression from the d15b block and the z6 head? i wasnt thinking and put regular in it today
also its using a dx ecu when i get the p28 should i get it tuned for the set up or dose that even matter?
tia guys if you have question ill awnser them the best i can..
Old Nov 7, 2011 | 05:02 PM
98civdx's Avatar
Master Detailer
Default Re: brake block question
That was hard to read. You need to proof read that crap. We can't help you if we can't understand it.
proportioning valve. I've never heard it called a block before.
They could need to be re bled, this is more then likely the issue. But, I suppose it could be the check valve.
Any cel's? Your runing your car with the wrong ecu, do you really expect it to run perfecly?
You need to get a chipped ecu, and have it dyno tuned. YES it does matter.
It may also need a tune up. Normally the wrong octane fuel would cause it to ping. Go put some 93 in it, and see if it fixes it. I doubt it will.
But, due to the high compression you may need to run 93 to began with. I don't know what the compression is, though.
Old Nov 8, 2011 | 02:56 PM
rpmraper's Avatar
thanks for your reply. im sorry if it was hard to understand i am disabled.. ..
anyhow no cel light, from my understanding, the only diff in the p28 and the dx ecu is vtec will not work.. aslo im guessing the car sat for a good while, all the tires were flat and it was pretty dusty on the outside.. also what is this check valve you speak of?
blue_hatch
Feb 8, 2011 11:09 PM
fireant
Dec 20, 2008 09:05 AM
RACEPAK
Nov 23, 2006 01:33 PM
madcrossover
Jul 21, 2005 10:33 AM
SMSP
42
May 25, 2005 06:15 AM
