ECT in 95 accord EX?
I cant seem to find anyone that can get me the right part. I have been given sensors that dont fit 4 times now.
My CEL is flashing a code 6 so I know it needs replaced. I also am not 100 percent positive which it is. There is one in the waterneck of the upper radiator hose and one in the lower radiator hose. there is also one that sits closer to the firewall behind the distributor.
I cant seem to find the right part and am frustrated!!!
help!
help!
Code 6 is the ECT sensor under the distributor, with the 2 wire connector (Grn/Blue wire and the Red/White wire).
The other ones you are referring to are thermo-switch A (lower radiator hose, near or on thermostat housing) and thermo-switch B (upper radiator hose), which would not cause the code 6.
importdps
Performance
763
Nov 6, 2012 11:13 AM
fsime
Oct 31, 2010 08:59 PM
