2000 turbo gsr b18
Old Nov 7, 2011 | 01:30 PM
B18254hp's Avatar
Default 2000 turbo gsr b18
Ok guys this is what my plans are. I bought the car about six months ago and it was already turboed.I drive the car every day for about a month. Now I have the motor pulled on it due to I want to build it as big as possible. So I am here to ask for advice on what to do and what others have done and what has worked the best for them. This is what I plan on so far I haven't bought any parts yet tho.
Pistons 9.0 to 1
Cams not sure what kind yet
Connecting rods probly eagle
Valves
Springs and retainers
Send block to b sleeved and cleaned up
Head work
And fuel not sure what to do about that
Sorry I sound like a retard but I have no idea about this motor
Old Nov 7, 2011 | 01:54 PM
B18CivicEJ8's Avatar
Default Re: 2000 turbo gsr b18
Originally Posted by B18254hp
Pistons 9.0 to 1
Valves
Head work
Pistons - CP, Wiseco, JE, Arias - Those brands are what most people at..
Stock cams are what a lot of us use, just get cam gears so you can adjust overlap
Rods - Golden Eagle, Pauter, Manley
Valvetrain - Supertech valves, valve springs and retainers. There are others, but I only have personal experience with Supertech.
Sleeves -As for sleeving, you must make sure the machine shop knows Honda engines. Any machine shop can do it, but you run the risk of your sleeves sinking if they are not Honda specialists.
Headwork - P&P definitely helps you might as well if you are going to replace your valves
Fuel - What is this for? Track only car or a daily driver car? If it's a daily, you may want to consider pump gas. What is the maximum octane at your gas stations? E85 may work for you, too, if there are a few E85 gas stations in your area.
I've given you very basic info.. You have a lot of research on your own to do...
Old Nov 7, 2011 | 02:07 PM
B18254hp's Avatar
Cool thanks and e85 we don't have that here the highest we got is 93 and ya I'm going to use it as a dd and thanks again for the advice should I bore it tho ?
Old Nov 9, 2011 | 09:36 PM
B18254hp's Avatar
Ok I got one more question that I hope u guys can answer for me when I bought the car the guy converted it to obd1 with a chipped p28 would I b best to leave it that way and what do I do for this new set I'm doing do I run a different ecu and get hondata or what would be the best for me on wiring ?
Old Nov 9, 2011 | 09:50 PM
racebum's Avatar
buy a stock p28 on ebay for around $90, boomslang conversion harness for another $90 and that 28 can be socketed for crome, neptune or hondata
Old Nov 11, 2011 | 10:42 AM
B18254hp's Avatar
One more thing to ask would it b smart to go with a set of 84mm cp pistons or is that to big ?
Old Nov 11, 2011 | 03:36 PM
nealnanoHX's Avatar
Why would he do all that? The car is already converted to OBD1 so all that is done. All he will need to have done is retune the for boost.
If you have a generic chip in the ECU the best thing to do is get a Hondata, Neptune or Crome when you have the tuning done. Leave it OBD1 as you will need it for the turbo tuning. No OBD2 tuning exists for OBD2 ECUs, only for K series motors which does not apply to use B series guys.
Old Nov 12, 2011 | 05:23 PM
B18254hp's Avatar
ok so i was looking at manliey rods today should i go with the i series or would the h seires work just fine ?
Old Nov 12, 2011 | 06:34 PM
digital sol's Avatar
H beam for boost
Old Nov 12, 2011 | 07:10 PM
TheShodan's Avatar
Moderator
Only if its sleeved.
You haven't even stated which engine you're using yet.
Old Nov 12, 2011 | 08:44 PM
B18254hp's Avatar
I am using a b18c1 and if u could share some of your wisdom with me it would be very much greAtful for me I would love to c the 500 whp range but would like to no what to buy to get me their and have the motor built proof as well
Old Nov 12, 2011 | 08:49 PM
meh..there is soooo much to list...theres a million ways to achieve your goals, you need to search and come up with more foundation questions..
overall power goal
budget?
track car? daily driver?
what transmission will be used?
what fuel will be used?
again...budget?
sooo many root questions that need to be answered before you can even begin to start your mental build....start with a plan and go from there....
Old Nov 12, 2011 | 08:50 PM
TheShodan's Avatar
Moderator
Unfortunately, that's impossible to do within a reasonable time. Start checking out setups that seem to be similar to the goals you want to set, as well as use of the car, budget for the kit and turbo (separate) and if you want to keep amenities like P/S and A/C. Check out the FAQs as well. The more specific, the better the shot of getting something you want..
Old Nov 12, 2011 | 09:37 PM
B18254hp's Avatar
Well I got a .70a/r turbo the intercooler and all the stuff for that all I need is the internals I plan on running the stock tranny with a stage 3 clutch. Also the best fuel I can get where I live is 91 pump gas. The car will not b my dd as I want it to b my take it out on the weekend and Cruz. I need a dd tho lol but I would only like to spend about 3500 and really want to achieve that 500 hp range if possible. Also I need hondata too is their a specific one I need, as for now I'm running a p28 chipped on the setup I have now but I did check out Californiadads build in this thread and if I could be at what he was at I would be happy. Sorry I don't really no what I'm doing and I don't even no where to begin or what to research. That is kind of y I am asking u guys cuz u have done this stuff and have a better Idea than I do
cheapshot
22
Feb 23, 2009 02:14 PM
cheapshot
Feb 19, 2009 05:48 PM
Tonyl507
Jun 2, 2006 12:43 PM
Hatchorama
Feb 9, 2006 08:09 PM
skrigz
Sep 6, 2004 11:32 PM
