anyone know of a large turbo that will work with a T25/28 manifold?
Old Nov 7, 2011 | 10:37 AM
Freshdot's Avatar
Default anyone know of a large turbo that will work with a T25/28 manifold?
long story short, I have a fully built d16 currently running an 18G on a edelbrock manifold. I simply want more power and this turbo is out of life at 22psi. does anyone know of something that will work with this manifold that can produce 450-550hp?
..this is a long shot, but preferably internally wastegated.
Old Nov 7, 2011 | 10:52 AM
Freshdot's Avatar
Default Re: anyone know of a large turbo that will work with a T25/28 manifold?
would something like this work?
http://www.atpturbo.com/mm5/merchant...egory_Code=GRT
Old Nov 7, 2011 | 11:27 AM
TheShodan's Avatar
Moderator
GT3071R can make about 440whp maximum output. The GT3076R or TR3030R could do about 480whp (GT3076R) -530whp (TR3030R) when pushed to its limits. To make 400-450whp, it is best to run externally gated to maintain optimal control, But the turbocharger needs to be 56lbs/min (Pushed) -61lbs/min not so pushed.
At that level, the edlebrock exhaust manifold that you plan to use will be much less effective at that power range anyway. This is what happens when you start to seriously want power; you much change a good portion of the setup as though you started over. Better get that D-series head REALLY UP TO SPEED before even considering this route
Old Nov 7, 2011 | 11:47 AM
Freshdot's Avatar
nevermind, i found it..will be making this purchase over winter
http://www.atpturbo.com/mm5/merchant...Category_Code=
my 18G is now for sale..PM me for more info.
Old Nov 7, 2011 | 11:50 AM
Freshdot's Avatar
you are very familiar with my build dude we talk alot on here lol...i have the fully built D running the 18G
Eglifestyle
Dec 11, 2009 08:32 PM
koulaid
Oct 21, 2008 08:17 AM
b18 hatch mike
Dec 28, 2007 08:35 AM
TurboHondaGuy
Welding / Fabrication
22
Nov 8, 2007 06:07 AM
turbochargeb18c
Aug 9, 2005 11:13 AM
