gsr swap in 98 ek coupe
I have a 98 civic that has a gsr swap. Unfortunately, it was recently kicked on the passenger side, that along with the hail damage is how i got this price.
i have pics of the new damage.
text 717 552-3 5 5 five
chambersburg, pa
3000 pretty firm
No rust.
b18c1 gsr swap with 70-80K-professionally done
S80 transmission
integra rear disc conversion
CAI
New Oem civic si motor mounts
Obx header
New stage 2 clutch
Type r cams
Has a/c which works
No power steering
has S2 lowering springs and coil over buckets but at stock height
New oem flywheel
New windshield
Inspected
Aligned
Si rims with good tires(2 new)
New headlights
new water pump
new timing belt
new oil pump
new starter
new front axles
new rear rotors
new rear pads
new rear bushings
new front rotors
new front wheel bearings
aftermarket ignition switch can be tricky if you aren't familiar with starting
bad-
Had some hail damage. Replaced hood and trunk
Couple dings in front fender
Passenger door looks like it was replaced
Rear quarter was sprayed.
http://i243.photobucket.com/albums/f...813_142712.jpg
http://i243.photobucket.com/albums/f...804_141058.jpg
http://i243.photobucket.com/albums/f...525_161955.jpg
can get more pics
chambersburg, pa
3000 pretty firm
No rust.
S80 transmission
CAI
Obx header
New stage 2 clutch
Type r cams
Has a/c which works
No power steering
New oem flywheel
New windshield
Inspected
Aligned
New headlights
new water pump
new timing belt
new oil pump
new starter
new front axles
new rear rotors
new rear pads
new rear bushings
new front rotors
bad-
can get more pics
92civicsib18c5
Sep 30, 2005 01:19 PM
