Would these civic hx rims fit my car?
I know little about cars. I found some 15in 4x100 civic hx rims with tires for $200 on Craigslist. I was
wondering if they will fit my 2002 Honda Civic EX Coupe. Thanks
yes they would fit since the offset needed for your car is the same as the offset needed for the HX, however i thaught the HX had 14" rims
This is correct. You'll also want to ensure that the tire size is correct for your car, as the HX wheels were on cars that had different tire size ranges.
they will most likely fit. the only problems people have with hx wheels is that the inside of the spokes sometimes rub the calipers . calipers are thick though. you could probably get away with grinding a litle material off or just get some cheap 4-5mm spacers for the front only. good luck
gotparts
Nov 20, 2004 03:46 PM
