BUILT 97 B18c1 GSR motor
97 b18c1 straight out of my 97 gsr LEGIT! The motor has 10,000 miles on it was just broken in when my oil pump wen't out. I thought I had spun rod bearings so I took it apart and what do you know everything was okay except the oil pump. No more time and money to fix it so I gotta sell it
The whole motor is still good just needs to be re-assembled since I took it apart to check all the bearings which means it needs a new headgasket and the head to be resurfaced.
97 b81c1 BLock:
RS machine Sleeves
81.5mm Arias forged turbo 9:1 pistons
LS Eagle Rods
LS crank
RS machine block ghirdle
ARP main studs and rod bolts
97 b18c1 Head:
Supertech Dual Valve springs (strongest pressure lb they make I believe)
Supertech Ti Retainers
Supertech SS Flat valves
Stock Gsr cams
This motor has everything on it (oilpan, etc...) Besides the Intake manifold and Valve Cover since I sold those already. I will take Resonable OFFERS ONLY! Don't try to offer me a stupid low price cuz it will be ignored.
FOR PICK UP ONLY IN SAN DIEGO/ESCONDIDO, CA or FRESNO, CA!
You can call me or text me at 559-824-9599 if you wanna check it out or find out more info on it. I will not waste my time and meet up or show the motor to you unless you have cash in hand and ready to buy (**** FLAKERS). This motor is Legit and everything is in Good condition.
The whole motor is still good just needs to be re-assembled since I took it apart to check all the bearings which means it needs a new headgasket and the head to be resurfaced. 97 b81c1 BLock:
RS machine Sleeves
LS Eagle Rods
LS crank
97 b18c1 Head:
Stock Gsr cams
spoon23_JDizM AkA SpOoN20
Sep 24, 2003 01:52 PM
