B18C1 low compression on cyl 4
Old Nov 6, 2011 | 04:11 PM
driftn_silvia's Avatar
Default B18C1 low compression on cyl 4
Alright guys, I have a b18c1, and had not driven it for a long time. Now its idle really bad, sounded like a subaru. I checked the injectors and pulled each clip at a time and cyl 1 & 4 stumble, and the 2 & 3 dont do anything. So i thought it was the injectors. That is not the case.
So i decided to do a compression test on the b18 and numbers came cyl 1 the one close to the cam gears is 150psi and the rest cyl 2 , 3, 4 got 215psi.
Now my question is, possible that i have a bad valve seal? or can it be a piston ring gone bad?
any inputs are great, and appreciated.
Old Nov 7, 2011 | 04:58 AM
kyden's Avatar
Default Re: B18C1 low compression on cyl 4
add oil to that cylinder and recheck. the 'subaru' sound most of the time is a burnt valve.
Old Nov 7, 2011 | 10:19 AM
i just added oil to cyl 1, and yes the compression went up. so it is a piston ring..
thanks for the input.
Old Nov 7, 2011 | 07:27 PM
Siriuswerks
Guest
Posts: n/a
You will need to perform a leak down test to locate exactly if it is a valve..Since you said that the car was sitting, put the engine to TDC and see if the lines meet.
cryingsuns
Jul 28, 2013 10:21 AM
ef9itb
Feb 6, 2011 06:21 AM
sirt_eg
Jun 16, 2009 01:25 PM
Mad Cow
Apr 15, 2004 09:29 AM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
