Tps Problem?
91 civic hatch std
d15b2-dx motor mpfi swaped
Alright so im in the middle of swapping shells right now and i pulled my motor from my car and put it in my new hatch which is the 91. i didnt touch the engine harness so none of my plugs are backwards. Only thing is my tps cracked somehow when i pulled the motor. So i thrrew another one i had laying around on there.
Anyways when i start it up its acts like its out of gas and spudders. It wont rev past 1500. At first i thought it was bad gas so i put new gas in there with some stp and tried a different fuel filter too. Nothing helped, but i unpluged the tps and it reved to 2200.
I dont understand, im not throwing anycodes, The motor ran perfect before i took it out. I triple checked my wiring for the mpfi and its good.
Any input would be great,
Thanks
Thanks
Also i just checked the voltage on the tps. i Got 3.72v at idle, and 5.02v at wot. I guess its the wrong tps? or its bad. The wires on the tps are switched around for the mpfi swap by the way.
hey just asking.... did you make sure all injectors are plugged in and working? it could have been the tps, but check your injectors. could have been a problem within a problem.
oh wait mpfi not dual.. nvm
Last edited by slowFTW; Nov 8, 2011 at 05:29 PM. Reason: skimmed instead of read :]
courts4dr
14
Dec 17, 2009 03:57 PM
sivik_outkast
Mar 1, 2009 04:00 PM
Se-rv-Tak
Feb 23, 2004 09:02 PM
