Exhaust help
Ok i need help picking out a new exhaust. Im looking for something with more power in the lower to mid RPMs. Is it ok to go with 2.5in diameter piping or will i loose all my low end acceleration. If anyone could give some opinions of which exhaust would be good. Also could i hook up just a muffler to my stock piping that has a 2.5in inlet and just use a reducer to fit it on the stock piping. Will i still get a low pitched sound out of the muffler if i do that or will it come out like a weedwacker sound? thanks for everyones help
For example, if you are planning on building the motor up (and sinking thousands into it) then you may want to consider 2.5" piping and go custom exhaust... by building up I mean... 3" intake, large throttle body, port matched intake manifold, port and polished head with high lift cam and adjustable gear. That would then allow you to take advantage of the larger exhaust piping.
If this is not something you want to do and you just want to slap on an exhaust so you can sound fast
then I'd suggest something nice at least like a Greddy w/ 2.25" piping. Hope that helps. Peace.
hey there, hit me up, i can set you up with mandrel bent custom catback 2.25 or 2.5" even 3" if your going turbo and all out..
i can guarentee it will be shipped and run you cheaper than any apexi system out there. Few ppl on here know and see the work.. email me for pics and more details
p3tey2
Nov 24, 2010 10:52 AM
