rivet drill bit.
Look at the rivet and try to determine the size of the shaft. Then go down to the store and get a metal bit the same size or a little bigger. I've found a bit that's a little bigger works better.
Here's a Google search URL:
http://www.google.com/#hl=en&sugexp=...=1920&bih=1037
(You'll need to click on the link. H-T compresses long links, so copy-and-paste probably won't work for you.)
