engine swap wiring
Old Nov 5, 2011 | 11:07 PM
BigbamaBen's Avatar
Icon2 engine swap wiring
I am swapping a ls motor into my 1990 crx dx. The car is dual point and I need multipoint. So I have a complete spare crx si harness laying around so could I just tear out the entire old chassis harness and put in the si harness and everything work fine right?
Old Nov 5, 2011 | 11:44 PM
crx_si-r's Avatar
Default Re: engine swap wiring
as long as the si harness is also from a 90-91 then yes. just remember where each connector goes or take pictures or mark them. also if you si harness is from an 88-89 then you will also need to swap in the matching cluster from the new harness.
or you can just convert your stock DPFI harness to MPFI and call it a day.
Old Nov 6, 2011 | 06:06 AM
D16SiHatch's Avatar
what he said, so long as you use both the si chassis and engine harness it will work just fine.
Old Nov 6, 2011 | 01:42 PM
BigbamaBen's Avatar
And they match the year it came out of for example 90 dx i would use a 90 or 91 si harness right
Old Nov 6, 2011 | 01:50 PM
all-motor-crx's Avatar
yes
91CRX-T
Aug 17, 2011 01:16 PM
BlendedEM1
Feb 13, 2011 07:06 PM
bradennicely
Jul 20, 2009 03:58 AM
ZAKU
Nov 18, 2008 04:15 PM
HondaHeddie
27
Oct 6, 2006 07:57 PM
