Exhaust Bolt Leaking Coolant
Old Nov 5, 2011 | 04:57 PM
steve66's Avatar
Default Exhaust Bolt Leaking Coolant
I have a 2000 GSR completely stock and was running great. I noticed a couple exhaust bolts broken so I pulled the manifold and tried to remove them. I got one out no problem, but the other was stuck and like a true man I tried to fix it myself. I drilled the bolt as close to center as I could and didn't even drill the hole to 6.8mm like the M8-1.25 bolt needs for tapping. Everything was going good, then I got about 2-3 threads tapped and it started leaking coolant.
My question is, is there any way to fix this or is my head done? If I need a new head, will a P72-1 be an exact match for my P72-2?
Old Nov 5, 2011 | 11:53 PM
RoTb TwEaK's Avatar
Default Re: Exhaust Bolt Leaking Coolant
The heads are the same exact thing the number 1 and 2 after the p72 only symbolize the year they are!like. P72-1 is from 94/95 98+ is p72-2
Other then that the heads are exactly the same
Here's a link chek it out
https://honda-tech.com/forums/acura-integra-type-r-8/p72-1-vs-p72-2-b18c-head-whats-difference-help-637499/
Old Nov 6, 2011 | 12:03 AM
Dioxine's Avatar
Thats a bust man
Old Nov 6, 2011 | 12:11 AM
10psiLsEf2's Avatar
No shit7 bump for a fucc up
Old Nov 12, 2011 | 06:41 PM
SQ is the SQUAD's Avatar
ive seen it happen with people running the threads in to far. get a new tight fitting exhaust bolt. lace the bottom of the threads that are going into the head with some red high temp rtv. let it fully cure before running the motor. if it dosent leak your good. try to get a good look into the hole. it might just be a pin size hole. make sure u use the red high temp rtv
Old Nov 13, 2011 | 01:08 PM
johnjw's Avatar
I've done this drilling broken bolts out on american aluminum heads, no need to get a new head. Permatex makes thread sealer, it comes in a white tube and looks like marshmellow cream. Works perfect. Part # 59235. Good luck.
http://www.permatex.com/products/Aut...ad_Sealant.htm
Swansen
Jun 15, 2015 03:26 PM
91EF919
13
Sep 3, 2009 11:47 AM
StrangerWitCandy
Feb 27, 2006 07:58 PM
Ls InTeGrA RaCeR
Mar 2, 2005 12:33 PM
BlueSi2k
Mar 31, 2004 01:56 PM
