First attempt at welding butt-joints
Old Nov 5, 2011 | 04:08 PM
b16bri's Avatar
Default First attempt at welding butt-joints
Finally got to do some wedling since the last group of pictures I posted. This time tryed to do some butt-joints. 1/8inch thick with a bevel on both sides useing .045 filer rod and machine set to 60-65 amps i believe I foegot to look before i changed it lol. They came out pretty good in my opinion for my first time. However I still had a litle issue with them warping it warped very little but still warped. I tacked both front back and middle to try and keep it from warping. what do you guys think.
Old Nov 6, 2011 | 12:52 AM
hoochhenry's Avatar
Default Re: First attempt at welding butt-joints
not bad
Old Nov 6, 2011 | 01:14 AM
Dioxine's Avatar
^x2
Old Nov 6, 2011 | 05:41 AM
b16bri's Avatar
Thanks do you guys have any advise ?
Old Nov 6, 2011 | 06:28 AM
tepid1's Avatar
Looks like you need to move a little quicker and possibly turn down the heat. How did the backside look?
Old Nov 6, 2011 | 07:47 AM
danedoremus's Avatar
better then my 1st time so not bad
Old Nov 6, 2011 | 10:58 AM
Dioxine's Avatar
This is what i was thinking. The beginning looked good but it seemed like you slowed down a little towards the end.
Old Nov 6, 2011 | 11:16 AM
b16bri's Avatar
Theres are the pics of the back side this is at about 55-60 amps or so. Is the little bit of warping i'm recieving due to me not moving fast enough. or to much heat ?
Old Nov 6, 2011 | 11:42 AM
Broman78's Avatar
I think preheating would help with the warping problem, and a little to much heat.
Old Nov 6, 2011 | 12:05 PM
b16bri's Avatar
noob question but how exactly would i go about preheating it
Old Nov 7, 2011 | 07:02 PM
Boosted_B_Series's Avatar
Ditto, too much heat in the material.
Looks like you brushed/cleaned up the welds after, which you shouldnt have to do.
Takes time, and a bunch of practice, but you will get it.
Also, make sure your using a gas lens. They are a must.
Old Nov 8, 2011 | 03:30 PM
b16bri's Avatar
Ok ill try and turn the head down how many amps would you suggust ? Also I didnt brush or clean them up at all. what gives it that appreance ? Another noob question i'm having trouble finding info on gas lens what exacaly are them and were can i buy them . dose the miller diversion 165 come with one ? do i need a bigger cup if i get a gas lens i have a # 7 on there now. Again sorry for the noob questions ive only been welding for a month
b16bri
Welding / Fabrication
15
Dec 23, 2011 07:28 PM
Bottle
Jan 1, 2009 06:12 AM
b14sleeper
Feb 7, 2006 02:11 PM
jakeiscool
Dec 3, 2004 09:14 PM
HeikDiesel
26
Oct 22, 2004 03:58 PM
