1st gen b16 alternator crapped on me..need to find alternative
since b16 alternator is like gold..i was told some other alternator will fit perfect. does anyone know which one fits perfect w/ 1st gen b16?
Jeff-
Jeff-
Talk to a guy on AIM.. irev210..
I got my b16a first gen alternator from him for 50 bucks. fast shipping, good guy! Tell him, Djay86 sent you!
oh yeah..one thing i forgot to mention was that my rpm gauge is going all over the place (up down up down) when I gas it...what problem could it be?
Jeff-
Jeff-
this seems like my same problem.....if I have the hood poped (or driving) an I hit the gas it sounds like it boggs down an then it catches up again in a little while. It almost seems like it isnt sucking in enough air....you think I am having the same problem as jeff? thanks need some quick help
edit: my rpm gauge jumps up an down too....like up an down about 1000 from where it should be
[Modified by xXsarcasmXx, 6:54 PM 10/7/2002]
Don't use a 90-91 LS alternator. They only put out 65 amps. I tried one on my b16 & kept getting the charge light when vtec was engaged.
I changed to a 94 GSR alternator, which puts out 90 amps & haven't had a problem since. The plugs are identical between obd0 & obd1 alternators, so no worries there.
Eric
Eric
Strange....since I'm driving w/a rebuilt LS 90-91 alternator from last winter...
Car is pulling strong all day.
Even with radio,lights,wiper and heater on....
used a del sol one on there right now, but its at the shop getting looked at. After 6 month with no problems. I will find out what went wrong
But the del sol one does fit. and worked.
jeff, keep me posted on what fixes it cause this sure is pissing me off
thanks again
-josh
thanks again
-josh
Jeff-
i've been using a junkyard 90-91 alternator, both on my old b16 and my b20 for about 9 months now..no probs.
well getting my car back tommarow. They found out that is was some bad wirring to the Alternator. (dont know how that could hav happened when all i did was plug the thing in) And the bolt was stripped. They got it fixed and i get to pick it up tommarow. Hopefully that is all that was wrong.
blackandblue
Apr 19, 2006 04:24 PM
