Need feedback on this chassis part list for fully built rally/drag/track CRX
Hey so I am going to purchase a CRX. Over time I will install all of these parts on it.
Plz give me some feedback what I can tweak/change/rework.
Let me know if any of these parts aren't compatible with eachother, won't play together nicely, have contradicting performance aspects etc etc...
Suspension + Chassis
Front
-Koni Yellow w/Ground Control adjustable-sleeve springs (adjustable ride height)
-Ground control 1" lifters for top suspension mount point (1inch lift basically)
-Shock tower 3pt tie bar (Password:JDM probably, the bar that goes over the engine in bay)
-Adjustable front sway bar (not sure on the brand, whichever is adjustable/quality)
-Front crossmember with traction control bars (Full-Race brand, if they retain OEM radiator compatibility)
-Front lower control arm tie-bar (connects both sides where LCA bolts to the shell, not sure what brand yet)
-H/X underbody brace behind FLCA (Megan racing? It looks like this http://www.innovativetuning.com/phpt...585&zc=1&q=100
-Side fender chassis stiffener braces (they go behind front fenders near door hinges, will be custom welded to shell)
-Full ES polyurethane bushings
Rear
-Aftermarket RLCA (weight reduction, bling, not sure what brand)
-Mugen/Hardrace trailing arm bushings
-RLCA subframe brace (ASR makes them)
-RLCA tie-bar (chassis rigidity, connects RLCA where they bolt into chassis)
-ST adjustable rear sway bar (connects to OEM tow hook locations and lower shock mounts on RLCA.)
-8pt weld in custom cage (same style as this, but custom made http://www.jegs.com/i/Jegster/550/94...oductId=758645
Wheels
-Enkei RPF1 17x10" (w/5-lug conversion, rolled fenders/possible spacers for fitment w/o rubbing.)
-Kumho Ecsta tires 17x10" (low-profile, nothing too sticky/expensive)
Other
-Lightweight racing seats (not sure on brand etc)
-Carbon fiber hood
-Carbon fiber hatch
-Lexan windows in rear/hatch
-Quick-release wheel/locking hub
-Short shifter
-Fully ES poly bushings everywhere in car
We aren't even thinking about the motor yet but it will be a fully built b20v.
Thoughts on current setup? Thanks HT
Front
Rear
Wheels
Other
-Carbon fiber hood
-Carbon fiber hatch
-Short shifter
THEhomelessONE
Aug 17, 2018 02:45 PM
Corksil
20
Nov 3, 2011 05:55 PM
00siandrew
Sep 6, 2006 08:37 PM
