Fully built 84mm Gsr with turbo kit for sale!
Well the time has come to sell my engine. I pulled my engine thinking I was going to put in a drag shell but just lost interested in it. So it has 2,500 miles on engine it made 514 WHP on 21 psi on E85. It ran out of fuel so either have to get bigger injectors or retune with different fuel to make 650-700 WHP. I really want to see it all go together I know that's not really going to happen but I would like to. So I listed what parts I have and the prices I paid yes it's what I paid not what I'm asking I know I won't back what I paid for it. But here is your chance to get a fully built 84mm GSR with a fully built ITR head. These are all the parts into my engine and what I used. No shortcuts were taking; all high quality parts were used. Get what you really want but save your bank account.
Golden Eagle sleeves:
Arias 84mm turbo pistons 9:1 comp
Eagle GSR length rods
CTR CAMS:
Skunk 2 cam gears
Victor x intake manifold
70mm omni TB with TB spacer
ARP Main Studs:
ARP Head Studs:
ACL Bearings:
OEM Bottom End gasket from Honda(front main seal, rear main seal, oil pick up gasket, oil pan gasket, tube Honda bond, timing belt cover gasket, and o rings)
84MM golden eagle head gasket:
OEM P72 timing belt:
OEM P72 water pump:
AEM fuel rail and AEM fuel regulator
Polished spark plug cover
Polish and chamfer crankshaft:
Competition Clutch stage 5 with flywheel combo:
OEM Type R oil pump:
OEM GSR Timing Belt lower cover:
Avid Lower mounts:
Supertech valves:
Supertech springs and TI-retainers:
OEM Valve seals:
Vtec O-ring gasket:
OEM CAM seals
OEM CAM plug:
MUTI Angle valve job:
MILD turbo street port on intake, only port match EX and Intake:
Surface Head
I have over 8k into the longblock. I'm asking 5,000.00 or interested in trades maybe a jeep wrangler, banshee, raptor, 450, just let me know what you got wrose I can say is no.
Also have my full turbo kit for sale as well. All top name parts here as well.
I have a 6262 ball bearing turbo just rebuilt not even 1k on it.
ALL IN FAB topmount 3" downpipe
ALL IN FAB stainless charge pipes
ALL IN FAB double back door frontmount, with Tial bov welded on it sounds good
44mm Tial WG
Also have full 3" skunk2 exhaust and some gauges left, AEM wideband and oil and boost auto meter gauges.
I want $3,500 for full tubro kit might be willing to part out. Also shoot me trade offers. Call or txt for more info thanks. 503 559 0761
CTR CAMS:
Skunk 2 cam gears
ARP Main Studs:
ARP Head Studs:
ACL Bearings:
OEM P72 water pump:
Avid Lower mounts:
Supertech valves:
OEM Valve seals:
Vtec O-ring gasket:
OEM CAM seals
OEM CAM plug:
Surface Head
44mm Tial WG
boosted.si04
Northwest (Sales)
37
Apr 11, 2012 09:38 AM
boosted.si04
Oct 23, 2011 08:47 PM
