Tachometer problems - Doesn't function
Old Nov 4, 2011 | 05:45 PM
lobby350's Avatar
Default Tachometer problems - Doesn't function
Hi guys, I just picked up a '98 EX 2 door with about 261K on it. Runs great and all but the tach does some goofy stuff. It doesnt work properly at all, right now its spun all the way around passed 8K pointing at about 6 o'clock. I've already gone back and spun it around back to zero, but the next time you start it it'll not move for a while or jump up, stop, and slowly creep up untll it stops at the 6 o'clock position again. What's my issue here, what do I need to test/check to see whats causing my issue and fix er? Thanks in advance
Old Nov 4, 2011 | 05:48 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Tachometer problems - Doesn't function
Sounds like it's broken to me.
Old Nov 4, 2011 | 05:51 PM
lobby350's Avatar
What exactly? It seems like its getting some kinda signal from wherever, but its all wacked out.
Old Nov 4, 2011 | 05:53 PM
The Grumpiest
The whole damn thing. Replace it.
Old Nov 4, 2011 | 06:02 PM
lobby350's Avatar
So your saying ill need to get a new cluster? Lol, sorry.
Old Nov 4, 2011 | 06:07 PM
The Grumpiest
Where did I say replace the cluster?
Old Nov 4, 2011 | 06:10 PM
lobby350's Avatar
Well the "whole damn thing" can mean the cluster...or something behind it. Or the car
Old Nov 4, 2011 | 06:13 PM
The Grumpiest
You were talking about the tach. I said replace the whole damn thing. I can't help what you want to infer.
ekz6coupe's Avatar
Your best off checking for your rpm signal if good replace the cluster or go with an aftermarket tach
Old Nov 4, 2011 | 06:14 PM
lobby350's Avatar
Where do i check for the signal?
Old Nov 4, 2011 | 06:18 PM
ekz6coupe's Avatar
Let me look for ya its been awhile since I've done that, its one of the wires coming out of the dizzy
Old Nov 4, 2011 | 06:22 PM
ekz6coupe's Avatar
Easiest way is there is a solid blue wire behind ur cluster that u can splice into,
Old Nov 4, 2011 | 06:23 PM
lobby350's Avatar
Ok thanks, and i assume that also gives the signal to the tach itself right?
Old Nov 4, 2011 | 06:41 PM
ekz6coupe's Avatar
Yes the blue wire is the feed to the tach if there is no signal it can run deeper then expected
Old Nov 4, 2011 | 06:49 PM
lobby350's Avatar
Ok thanks, ill check that out and come back with what I find.
Old Nov 6, 2011 | 08:56 AM
vinem1's Avatar
So how did you fix it ?
Old Nov 6, 2011 | 09:30 AM
dumpedeg16's Avatar
it could be the dizzy
Old Nov 6, 2011 | 03:05 PM
lobby350's Avatar
Haven't gotten to it yet it's currently at my uncles right now hopefully ill be able to check it out tomorrow.
Old Nov 8, 2011 | 08:55 AM
E_Del's Avatar
lol my 2000 DX doesnt even have a tach . . . lucky
Old Nov 9, 2011 | 10:24 AM
lobby350's Avatar
Ok so i just used the little test point with the trusty ole multimeter and it was saying about 700rpms at idle which of course is normal. So does this mean the signal coming from the distributor is fine and the problem lies in the tach itself?
Old Nov 9, 2011 | 12:42 PM
TOO MUCH TORQUE's Avatar
jumping tachometer = dying ignition ignitor.
Old Nov 9, 2011 | 12:44 PM
lobby350's Avatar
Even if it sends a normal signal to the test plug?
-A more detailed description of the problem now that I've been driving it: When just normally driving sometimes it seems to just stay down at zero. When cruising sometimes it'll catch my eye jumping up to 6k and then slowly moving up, or just staying there. When i shut the car off it goes back to the 6 o'clock position.
Old Nov 11, 2011 | 05:59 AM
lobby350's Avatar
bump
Anyone? The test plug wire comes off of the same blue wire that goes to the tach right? So if the test plug is reading right, then it must be something in the tach itself right?
Old Nov 11, 2011 | 07:45 AM
Former User's Avatar
Replace the tachometer or cluster.
Old Nov 24, 2011 | 08:18 AM
lobby350's Avatar
Finally found a used OEM tach unit on ebay, just installed and it works just as it should. Thanks everyone
