HELP: Want to keep Powersteering in my Integra GSR with B20B Swap
Like the title say, i would like to have powersteering. I have an 95 Integra GSR with a b20b swap and would like to have powersteering. What do i need?
Should bolt up I believe, if not, you will most likely need a GSR ps pump, and brackets.
Since the GSR head isnt as tall as the LS/b20, it might use different brackets. Your best bet is to go to oemacuraparts.com or acuraoemparts.com and compare part numbers and picture diagrams, they can usually depict interchangability. GL!
Also, if you want a complete LS/b20 power steering setup (all lines, pump, brackets, bolts, etc!) I Have one, I did a PS delete on my LS
