***DA 90 93 -Integra Race Car part out***
*****UPDATED LOOK BELOW FOR NEW ITEMS*****
Starting to part out my 93 Integra Race Car. I ran this car 3 times at Cali Speedway in the past 3 years. Everything is pretty much brand new. I will be posting stuff up as I take it off.
Call or text me 714 476-twenty one 84 .... John
***NEW ITEMS****
If you need any parts let me know..
Stock
-taillights both 80 obo
-radiator with fan attached. like new 125 obo.. no leaks
-hoses/clamps
-alternator
-65mm JG throttle body all sensors
-15/16 brake booster
-engine mounts both sides and rear.
-brake prop valve.
hit me up with what you need from car... pm or text... panels for car for sale too... everything straight.
***NEW ITEMS****
Stock
-hoses/clamps
-alternator
-brake prop valve.
Built engine... Was built by a garage called "Speed Garage" in Irvine back in 97. It has about 15,000 miles on it as this motor sat for most of its life. Was my friends motor back in 97 and then gave it to my other friend who put it in this DA. I bought the DA four years ago and used it at the track 3 times. Before I purchased it,it sat in his garage,the DA, for about 10 years as he would start it and run it around the block to keep the engine going.
I will open the oil pan and take pics. Do know they are low compression forged pistons, with aftermarket rods, arp rod bolts, not sure of bearings, sleeved(not sure how big maybe slightly over stock). ARP head studs.
Engine WAS RUNNING when I parked it and started to dismantle everything. Engine did not smoke or anything. Engine was boosted on back in the day with 6-8psi and he went up to, i believe, 15psi when he wanted to drag.
So this is what I want... just to get rid of it as my uncle is on my *** to get this car outta his driveway.
$500OBO for block gets it or best offer... you could probably sell the parts individually for more...call me for more details. 714 476 twenty one 84
B18A sleeved (maybe a little over stock)?
Forged Pistons - Not sure name?
Forged Rods - Nots sure name?
ARP rod bolts
Arp head bolts
Bearings - ?
ARP rod bolts
Arp head bolts
Bearings - ?
thanks for the traction bars John. This guy takes care of his car parts. Would have picked up the asr setup if I didn't already have the progress bar. Heck, I am debating if I should put the progress on the DA and use the asr for the db2.
Bump for a great seller.
Thanks homie for picking it up. You just got a hell of a deal. I keep my stuff clean, I hate scratched and dirty sh*t...
