NJ DOPE SC400 fs/ft caged v8 manual!!
Old Nov 4, 2011 | 04:59 PM
TrexM3's Avatar
Default DOPE SC400 fs/ft caged v8 manual!!
*****need this gone this week or im just keeping it in storage .. have my dd lined up and need more $$ for the downpayment so no trades anymore unless its a sick ls1 FC or built right s14 ******
Specs
1992 SC400 with 112k original miles Black on Tan. 1UZ-FE (V8)
Supra R154 trans had 78k miles when pulled from the car "I just replaced the last one due to a few bad synchros.
Specs
the sc400 was never offered in a manual and there are barley any swaps out there ive only ever seen 4 total between youtube and the forums..
1uz and trans are strong and can be vouched for
POWAAA
S-AFC (tuned)
Custom equal volume long extractor headers (Rush AU)
Carsound cats, x-pipe, flowmaster mufflers
Walbro 255LPH high pressure fuel pump
1.5 way LSD from 94Supra N/A with 4.27 gearing
Custom one-piece driveshaft
SUSPENSION ISSHHH
8-point full roll cage
Daizen Front Control arm bushings
Daizen Rear Control arm bushings
Daizen Front and Rear Sway bars
Daizen front and rear sway bar bushings
TEIN HA coilover system
Daizen rear camber control kit
LOOKERS
Just got it out of the body shop, the car has zero dings or scratches.
door cards
Origin front bumper
Origin rear bumper
Vertex rear spoiler(i removed it but still have it)
HID low and highbeams
V-speed side skirts
Painted Carbon Fiber Hood with hood pins
GUTSSS
Cage "unpainted but prepped n ready for paint"
98 Supra TT front leather seats
Clarion 2din CD/MD player
"have single din setup,waiting for some time to put it in"
Custom Laser blue dash needles(by lextech lighting).
Nakamichi factory system
replaced climate control lights with 97+ scheme
optional cupholder added
ROLLIN N STOPINN
I-forged 19x8.5F 19x10R "need to be refinished or powdercoated"
Tires = 245/35/19F 275/30/19R
Supra TT front brake upgrade with cross drilled rotors (Brand new)
Lexus SC brakes rear (Brand New)
Goodridge SS brake lines (all four corners)
EXTRA
A/C system converted to R134 from R12
New Supra spare
mmm NEW STUFFF
CRD custom bellhousing
CRD custom flywheel
CRD custom ring gear
Exedy Clutch
Exedy pressure plate
Spigot Bush (this is from a turbo MKIII)
Throw Out bearing (this is from a turbo MKIII)
slave cylinder & push rod (this is from a turbo MKIII)
Slave cylinder and bolts (this is from a turbo MKIII)
release bearing (this is from a turbo MKIII)
pivot ball (this is from a turbo MKIII)
(6) M12 x 1.25P x 50 long original
Toyota
bolts -bellhousing to motor (OEM)
CRD supplied (3) M10 x 1.25P x 45 long original Toyotal Bolts - Bellhousing to motor (OEM)
CRD MKIII turbo slave cylinder (this is from a turbo MKIII)
*R154 transmission from soarer
TT
(this can be from a turbo MKIII)
*MKIV soarer TT tailshaft (this is from a late model MKIV
pilot bearing (from a turbo MKIII)
Flywheel flex plate bolts (8) M10 x 1.25 pitch x 26 long High Tensile Bolts. (OEM)
SC300 clutch pedal 58804-24030-03
SC300 clutch pedal box sub assembly 47101-24060
SC300 brake pedal
SC300 brake pedal box sub assembly 31301-24050
SC300 clutch pedal pad 31321-14020
SC300 brake pedal pad 31321-14020
SC300 shifter boot
SC300 shift ****
SC300 shifter trim bezel (specify with or without heated seat)
supra 6speed master cylinder 31410-14310
SC300 hardline for master cyl
MKIII turbo hardline for slave cyl
bads- needs a extremely good interior detail
** car currently is on a winter 350z setup and might be having the iforged refinished**
**yes i have the other seat i keep it out when im transporting tires**
maybe ill get some pro pics taken soon so you can see more then the crappy phone pics
9K THIS WEEK ONLY!!!! 8.5k with the z wheels... 856 725 7566 or pm
how it sits currently
Old Nov 4, 2011 | 05:25 PM
1A4's Avatar
1A4
Default Re: DOPE SC400 fs/ft caged v8 manual!!
Nice ttt
Old Nov 6, 2011 | 07:14 PM
Hankish's Avatar
bump!
Old Nov 7, 2011 | 10:50 AM
reydar1's Avatar
dope...bummmppp dissss
Old Nov 7, 2011 | 01:37 PM
jgraham0326's Avatar
SICK!
Old Nov 9, 2011 | 04:39 PM
TrexM3's Avatar
thanks guys .. bump it up
Old Nov 9, 2011 | 08:45 PM
Getownit's Avatar
This things sexy! id **** it out if i had 10k and have soo much fun
FREE
Old Nov 9, 2011 | 10:20 PM
FAITHhasME's Avatar
any numbers?
Old Nov 9, 2011 | 11:00 PM
TrexM3's Avatar
FREE
thanks man all serious cash offers will be listened to i need more $$ for a down payment on a new dd!!
Old Nov 10, 2011 | 03:24 PM
TrexM3's Avatar
B B Bump it up!!
Old Nov 13, 2011 | 10:48 PM
TrexM3's Avatar
bump , keep the offers coming
Old Nov 25, 2011 | 06:16 PM
TrexM3's Avatar
any last minute trade/cash offers before shes traded this weekend
Old Nov 27, 2011 | 04:43 PM
TrexM3's Avatar
bumpp it uppp
Old Nov 27, 2011 | 06:21 PM
Mr.OB*GYN_Rhett's Avatar
lawd, dope whip!
Old Nov 30, 2011 | 10:34 AM
TrexM3's Avatar
bumppppp
Old Nov 30, 2011 | 11:46 PM
Benj@mmin's Avatar
Awesome car man, well done. What state are you in?
Not sure if this is a s14 done right to you but I'd trade.
http://hondamarketplace.com/showthread.php?t=2977696
Old Dec 1, 2011 | 01:47 PM
TrexM3's Avatar
im in nj . nice s14 just to far , glws
TrexM3
Feb 23, 2012 12:57 PM
TrexM3
Nov 20, 2011 05:47 PM
Rzoops
Oct 4, 2010 05:36 PM
Rzoops
Southeast (Sales)
Oct 4, 2010 05:07 PM
reebs
Sep 19, 2008 12:02 PM
