PA Fs: 87 Crx Dx..built D16a1 Turbo Motor/rare Parts
Old Nov 4, 2011 | 01:56 PM
staticchmbr's Avatar
Default Fs: 87 Crx Dx..built D16a1 Turbo Motor/rare Parts
so.. here it is. i have been collecting parts since i joined the site. i have already sold a bunch of parts on here.. and now its time to sell more. life has taken a turn, and i can no longer take time to build this car, and put money into it. as you know, almost all of this stuff will also work for your 1g! .. make an offer on stuff
car: 1987 crx dx silver 2 tone with 85k on the body $500
engine... sold as complete motor and transmission ONLY!!!
THE PRICES NEXT TO THE PARTS ARE WHAT I PAID FOR THEM
head:
-87 d16a1 port and polished head $250
-jg reground zc turbo cams $250
-jg adjustable cam gears $150
-jdm obd1 dohc intake manifold $150
-throttlebody spacer $50
-'98 b18b throttlebody (60mm) $50
-*optional* intake manifold adaptor for use of sohc manifold $100
-*optional* OBX sohc intake manifold $75
-hondata intake manifold spacer $25
-custom powdercoated valve cover (blue) $100
block:
-stock bore d16a1 REBUILT with about 100 miles $400
-new ACL rod/main bearings $100
-tuner toys h beam rods w/ larger rod bolts $270
-custom 9:1 wiseco pistons (made for d16a1) with turbo rings $600
-filled block (devcon) $40
-bored oil pump (endyn type) $40
-new seals/water pump/timing belt/tensioner/etc $150
-dc sports oil filter adaptor (built in oil feed line holes) $60
-HKS MLS headgasket $130
trans/suspension:
-d16a1 trans with OBX LSD installed $400
-new clutchmasters stage 2 clutch/throwout/pilot $250
-accord 5th gear set $25
-RARE monkeyztek 450 LB rear coilovers $250
-barely used kyb front/rear struts $200
-custom made rear sway bar mounts (aron d.. not installed) $45
fuel:
450cc dsm blues injectors (stock 240 until the turbo was going to be put on) $75
obd1 fuel rail $50
walbro 255 fuel pump $100
electronics:
-xenocron chipped pm6 ecu with socket to run 2 programs (no chip installed) $125
-laptop with turboedit and ecu control installed (piece of poo old laptop, but its free) $50
-willem ecu chip burner (old and needs to be plugged into a serial port.. works great!) $60
-a ton of 512 chips.. can handle 2 programs each $40
-LM1 wideband kit.. includes barely used o2 sensor $285
-apexi safc (just in case) $120
-some boost gauges $50
-crane cams ignition pack/coil (not installed) $250
turbo/exhaust: (turbo stuff is not installed)
-rebuilt t3 60/48 from turbocoupe $250
-tsunami turbo manifold $200
-sfp 2.5" mandrel downpipe (needs to be adjusted to fit this manifold.. was built for turboxs model) $200
-turboxs 38mm wastegate and dump tubes $100
-greddy type s knockoff BOV $80
-2.5" mandrel intercooler piping.. some 2.25 $150
-custom 2.5" exhaust bends (needs to be welded.. stock exhaust on there now) $150
-vibrant black muffler(again, needs to be welded in) $80
-high flow cat (same as above) $50
-golden eagle vacuum manifold $30
-MBC $15
-cca front mount intercooler $200
body:
-mint crx si side skirts and door panels(not installed, and may need black moulding)
-extra fenders (some cracks and missing tabs)
-extra header panel.. (some cracks and missing tabs)
-extra rear center panels
-crx si front and rear bumpers
interior:
-DIGI DASH $300
-RPR custom black shift **** $40
-DC sports slightly used short shifter (not installed) $100
-ac delete vent $40
the bad... ok so, it has rust.. in the rear quarters (not really bad) and in the floor pans.. pretty bad. if you can fix it, your golden! if not, you would be best to take the parts and start with a new body. need the exhaust to be finished as well.. all of the parts are there
to be continued... sorry.. i have to try to think of what else is included.. throw up some offers!
Old Nov 7, 2011 | 01:55 PM
Default Re: Fs: 87 Crx Dx..built D16a1 Turbo Motor/rare Parts
bump!!
Old Nov 17, 2011 | 02:21 PM
bump!
Old Dec 17, 2011 | 09:09 PM
mackinaz928's Avatar
pics?
Old Jul 18, 2012 | 06:52 PM
cbobrx's Avatar
Icon2 Re: Fs: 87 Crx Dx..built D16a1 Turbo Motor/rare Parts
Dumb Question.
Do you still have the d16a1 to sell?
Bob
Old Jul 18, 2012 | 07:01 PM
AllMotorRP's Avatar
Yea pics...?
Old Jul 18, 2012 | 07:09 PM
LoveMyAccord's Avatar
may I ask why you have an account on a honda thread account but yet your photo is like a facebook photo, THIS IS NOT FACEBOOK I escape facebook w honda tech
Old Jul 20, 2012 | 04:28 PM
onefastegg's Avatar
You guys realize this is almost a year old right?
goldhatch94
Northeast (Sales)
Sep 23, 2008 09:55 PM
vib
Southeast (Sales)
Apr 20, 2008 01:17 AM
vib
Apr 20, 2008 01:15 AM
