Rod Knock? Spun Rod Bearing? - Video Included
I've had this knocking sound for probably 1+ years and 13,000 miles now. Over that time i believe it's gotten a little worse. The head was rebuilt a few months ago, which didn't change anything with the knocking sound. The valves are adjusted correctly. The video below is for a vacuum leak I was trying to show someone, but you can definitely hear the knocking I'm talking about. Just disregard everything I say in the video, because that problem has been fixed.
What do you think?
http://www.youtube.com/watch?v=4T7BVZv9DPc
What do you think?
The knocking happens when:
1) The engine is warm, not cold
2) There is no load on the engine
3) Also occurs about 80% of the time, not 100%.
I have not tried disabling the injectors, I'll do that once it stops raining.
I've watched every last video on youtube on engine knocking sounds. Some said it turned out to be their valve clearance, others said timing belt tension, or rod bearings. I don't know if this helps, but here's another video on my (what I presume to be) Timing Belt Auto Tensioner failure, which happened when I had a shop rebuild my head last April.
Please watch the whole video; it gets nasty after 34sec
http://www.youtube.com/watch?v=sGffyaZQ4bo
The noise of that H22 sounded similar to mine. Mine sounded more like a helicopter though. Turned out to be my timing was a bit on the loose side which causes to create that loud flapping noise that sounded like a helicopter. I properly tensioned my t-belt and it got quite.
Both videos sound very similar, I would check the timing belt.
You can kinda hear the valves under the "helicopter" sound. I think you need a valve clearance adjustment anyways. Might as well do it while you're in there.
i very much doubt its a spun bearing mate, your engine would only last a few seconds/minuites.
just out of interest what does it do if you put the clutch peddle down?
The clutch works fine. I can put it to the floor with no problem. I just have a slight whistle with the throwout bearing though.
If your oil isn't full of micca flake then it's probably not a spun bearing. It would certainly not last 13000 miles if it were.
I'd check cam timing, valve lash (again) and ditch the auto tensioner if you haven't already.
You've got a '97 SH? It could be the LMAs ticking too. In '98 is when they switched to the beehive-style LMAs. It's not trivial to replace them but it's not the end of the world either. All 8 are ~$70 new but you'll need some shims/washers to get them to an acceptable intalled-height.
-P
-P
I was thinking it could be the LMAs, but i couldn't find anything online about h22s having LMA issues. I also didn't think they'd cause a sound this loud though. I do know about the change from cylinder style to spring style LMAs. And the last thing I read about them mentioned that Honda no longer carries the cylinder style LMAs, but only the spring ones. Which lead me to believe that they'd fit perfectly in the h22 without shimming. I could be wrong of course. I'll press down on the LMAs with my finger to see if they stick.
If a cam gear was off by a tooth, would that be enough for a piston to hit a valve? The manual tensioner conversion kit should arrive by UPS today, so I'll be swapping that auto tensioner out soon.
Oh, and one more thing. The deisel sound is there when the motor is cold too, not just when warm. It's just not as easy to hear when idling cold.
Were you able to use the 1999+ LMAs on the 1997? I think I'm having the same noise now too. Some folks from PO.com and PP.com suggest to readjust the valves again, but I'm leaning toward the LMAs at this point. It's just that the LMAs for the 1997 models cost 3x more than the newer model ones.
1997 SH
14820-PCB-305 LOST MOTION ASSY $23.10
1999+ (?)
14820-PCB-003 MOTION ASSY., LOST $8.05
These were taken directly off from majestic auto parts. Let me know. Thanks!
Btw, not trying to jack your thread but here's how mine sounds..maybe you can help me pinpoint it.
http://www.youtube.com/watch?v=s6txuqjrnSE
1997 SH
1999+ (?)
What do you think?
What do you think?
One tooth should not be a problem for valve clearance. It will mess with your power band / drivability however.
mine sounds just like yours i got a new tb job and it still happened but it didn't affect the performance one bit and now my auto tensioner went out I'm thinking of going with the kaiezen speed tensioner anyone have it? i want some reviews plz
--TJ
Thats the inside of my oilpan and I did not see ANY flakes in my drained oil or on the magnetic plug. To be sure, you gotta pull the pan and see for yourself.
amtrak23
Oct 27, 2015 07:49 AM
PerfectionIsKey
Jan 28, 2013 09:53 AM
hatchback_al
13
Apr 25, 2004 09:29 PM
