FS: Garage Clean-Out H and B Series
Bart Taylor Look-alike
***Updated 1/28***
Still cleaning out my garage of random parts I still have after selling my H2B Civic. The car was running strong when I took it a part a couple years ago to prepare for a full-drag build, but I never finished I'm located in Riverside and Pomona areas. I am willing to ship small items.
PM me if you're interested in anything. Thanks.
Here's the current list:
First...the Random Item
Large DVD Collection (103 Titles) They all have their proper cases and are in good condition, some have hardly been watched, if at all. If you are seriously interested and curious about the titles you can PM me and I will send you the list.
SOLD
http://i75.photobucket.com/albums/i3...g/IMG_5883.jpg
Pedal Assembly and Clutch Slave/Master for an EG Quite a few main parts needed to do a manual swap. Obviously needs to be cleaned up quite a bit.
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1607.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1608.jpg
Brand New H22 NGK Plug Wires (RC-HE65)
$60
http://i75.photobucket.com/albums/i3...g/DSCN1404.jpg
H22A1 Bare Block, needs to be sleeved, it's already been bored. Has an oil pan, oil pick-up, mains and girdle. Great if you need a spare block to be sent out to get sleeved.
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1596.jpg
H22 Intake Manifold with Throttle Body. Willing to part-out if you need any specific piece.
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1598.jpg
Type S Pistons on H22 Rods (50mm). Cylinder one's piston landing went-out, all the others are fine.
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1600.jpg
H Series P13 Lower Timing Cover
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1602.jpg
H22 Alternator Wiring, this is the piece that connects to the valve cover
$10
http://i75.photobucket.com/albums/i3...g/DSCN1606.jpg
H Series Fuel Pressure Regulator (2)
$10 each
http://i75.photobucket.com/albums/i3...g/DSCN1603.jpg
Various Thermostat Housings (if you see something you need just let me know)
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1605.jpg
H22 Alternator Bracket
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1288.jpg
H22 Rear Transmission Mount Bracket
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1287.jpg
F22B1 OBDII Distributor from a 97 Accord
$50
http://i75.photobucket.com/albums/i3...g/DSCN1293.jpg
H/F Series Alternator
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1609.jpg
H/F Series Crank Pulley
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1604.jpg
H22 Intake Manifold Double-Stacked Plates and Gutted
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1384.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1386.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1385.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1387.jpg
H22 Oil Pump with Balance Shaft Removal Plugs--only a couple thousand miles on it--I also have balance shafts that have been cut, PM me and I can explain if you're interested.
$75
http://i75.photobucket.com/albums/i3...g/DSCN1377.jpg
H22/H23 Seal
$10
http://i75.photobucket.com/albums/i3...g/DSCN1392.jpg
H22/H23 Oil Pick Up
$10
http://i75.photobucket.com/albums/i3...g/DSCN1391.jpg
H22/H23 Dipstick
$10
H22 Valve Cover
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1573.jpg
RC 440 Injectors (SL4-440)
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1400.jpg
MSD 8.5mm Plug Wires--they need boots
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1378.jpg
H22 Head with cams, caps, and VTEC solenoid--water was left in the water jackets too long need to be cleaned up.
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1397.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1393.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1395.jpg
Euro R/Type S H22 Valve Cover
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1388.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1389.jpg
H23 Crank
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1280.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1282.jpg
H23 Pistons and Rods
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1279.jpg
Converted External Coil Distributor used on H22 and MSD 6AL Ignition + Coil
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1301.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1298.jpg
STR H22 Fuel Rail and Cam Seal
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1247.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1237.jpg
Intake Velocity Stack 3"
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1399.jpg
B Series Mounts with Urethane Inserts
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1286.jpg
92-00 Civic Fluidyne Radiator (FHP11-92CIV)--water was left for a while like i said before might need to be cleaned a bit.
SOLD
http://i75.photobucket.com/albums/i3...DSCN1379-1.jpg
http://i75.photobucket.com/albums/i3...g/DSCN1383.jpg
P30 B Series Starter
SOLD
http://i75.photobucket.com/albums/i3...g/DSCN1284.jpg
SOLD
SOLD
$60
SOLD
SOLD
SOLD
SOLD
$10
$10 each
SOLD
SOLD
SOLD
$50
SOLD
SOLD
SOLD
$75
H22/H23 Seal
$10
H22/H23 Oil Pick Up
$10
H22/H23 Dipstick
$10
H22 Valve Cover
SOLD
SOLD
SOLD
SOLD
SOLD
H23 Crank
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
Interested in the parts below!
H22 Starter
Do you have the mounts for eg/dc?
PM plz!
H22 Starter
PM plz!
