My 98R, showa or denso raditor, where do I look to confirm?
Guys, I'm considering replacing my radiator with a koyo racing radiator. I looked yesterday to try and find some kind of stamping or sticker but could not confirm. I did not get under the car to take a look. When I searched I found a thread saying ITR's have densos but Ive found other threads saying otherwise in other forums.
Any help is appreciated? Also, those ITR owners with factory A/C, has anyone had to replace their condensers? the top of mine is rusting and corroding pretty bad. just wanted to see how much work goes into replacing the condenser.
Thanks in advance!
Thanks in advance!
I've seen and owned both the Showa and Denso. Do you have a picture of the top? Also, check the cooling fan (not compressor fan). The number of blades determines which one you have.
Here are some pics I just took Cheez. Looks like I have 5 blades on the cooling fan, if I picked the correct fan. Thanks.
