► FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Nov/Dec 2011
This thread is a privilege so please abide by the rules. Users with several infractions to the rules are subject to losing % points, privilege, and/or being removed from the site.
RULES:
1. NO TRIAL USERS!
Once you sign up for honda-tech, you will be a trial user until you have at least 10 posts, belong as a member for 7 days, and do not lose any % points.
2. Prelude, specific classifieds only
This means no posting up anything other than prelude related items only.
3. One POST per month
Only one post per member per month. Multiple posts for different items will be deleted and you will be subject to privilege losses. You can edit existing posts if you have more items. This can be done by finding your original post and clicking EDIT. Deleting old threads and making a new one in order to remain on a newer page is also against the guidelines.
5. NO PICTURES
Pictures can be linked, but not inserted. Pics with IMG tags will be edited and/or deleted. Subject to point loss and/or privilege loss if done. Also, do not post in larger font sizes.
6. NO REPLIES OR COMMENTS
No replies or comments about anything listed. This is a READ-ONLY thread. Use IM or e-mail to contact the user. You can obtain this information by clicking the user-name of the individual posting the part for sale. If you are a trial user and cannot PM individuals you must wait until you are no longer a trial user to PM them. Do not change font size or color.
RECOMMENDATIONS:
7. Make a post in the classifieds and link it (optional, but recommended as you can receive no replies here)
8. As items sell, edit and/or delete your posts so the thread stays current. Although automatic cleanup will can your posts in 3 weeks. Do not change font size or color.
9. Save the text of your post, or you will have to re-write it every time it gets deleted.
RULES:
1. NO TRIAL USERS!
5. NO PICTURES
RECOMMENDATIONS:
First!
Im selling my h22a1 block. When it was in the car we tested compression and it was 220 all the way across, not that it matters put people like peace of mind.
Did not burn oil, not that i knew of. Oil pan gasket was JUUUUST replaced brand new.
Comes with whole rotating assembly.
Prefer pick up. Located in ohio
Looking for 350 obo!!! 614-581-7201
-cody
-cody
I also accept local trades as well. Unopened Honda fluids, Unopened motor oils of my liking, cash, and car parts.
F/S New OEM parts for 1999 Prelude Base Model. Check part numbers.
(3) 95701-10050-08 power steering bracket mounting bolts. Used.
06923-P0A-306 TSB part for front balancer shaft. For you 4th gen Prelude guys with the older motors. $3 shipped.
BNIB Luk clutch release bearing $25 shipped
Honda brochure for 1999 Prelude Base and SH model. $15
91206-PX5-005 oil seal for passenger side axle to transmission $6
01463-ST7-R00 Front Brake Caliper Rebuild Kit $20
Front Upper Control Arm. 51460-S30-003 for the left side $80
44017-S0A-J02 x 2 inboard boot set Manual Transmission $18 a kit
44018-S9A-010 outboard boot set Manual Transmission $18 a kit
Honda CV grease outer 08798-9007 x1 BNIB $4
Honda CV grease inner 08798-9003 x1 BNIB $3
Honda Cemedine Adhesive, auto body supply used for water leaks and weather stripping. Best offer.
Some misc stuff like new and used clips for inside of the trunk, and for the side skirts.
16" ENKEI Wheels:
http://hondamarketplace.com/showthre...8#post46306198
Also have OEM headlight. Fantastic condition. Need it gone. $20
Comp Clutch h22 twin disk, minimal street duty, handfull of passes at the track. $700 shipped
H22 valvecover, 5th gen (its the gray oem color not black) $40 plus ship SOLD
H22 vtec solenoids, have severa $25 each plus ship
I have USDM 92-96 tweeter covers, these are do not have the foglight switch cutout, no broken tabs, great condition. $50 Shipped pics available upon request.
Also have majority of h22/h23 manual belt conversion parts BNIB. PM if interested
I have a 98 AUTO Prelude that I'm doing a full part out with, so if anyone needs parts, just let me know
http://www.preludeonline.com/f30/fs-...artout-265501/
For Sale:
**1997-2001 Prelude base model interior door panels in great condition! I was going to redo the inserts and armrests but have decided to go a different route with my car. Here is the write-up of what I was going to do: http://www.preludeonline.com/f60/diy-5th-g...-panels-240655/
$150 plus shipping for the pair
http://i975.photobucket.com/albums/a...lpassenger.jpg
http://i975.photobucket.com/albums/a...aneldriver.jpg
Typical scuff marks:
http://i975.photobucket.com/albums/a...anelscuffs.jpg
**Swift Race Springs
$100 plus shipping for the pair!
2.5" inner diameter
8" tall
10k spring rate (roughly 570lbs)
These only have one season on them and the photos were taken just after taking them off of the car. Needless to say, they are in nearly new condition!
http://i975.photobucket.com/albums/a...spairsml01.jpg
http://i975.photobucket.com/albums/a...ring2sml01.jpg
http://i975.photobucket.com/albums/a...ring1sml01.jpg
Happy Luding!
Brian.
2.5" inner diameter
8" tall
Happy Luding!
Brian.
h22 turbo kit included:
Hytech turbo manifold t4 divided
pwr liquid to air barrel intercooler 3in inlet and outlet
3in piping bead rolled with a 50mm blowoff valve and couplers
electric water pump
aluminum ice box
t4 divided turbo non ball bearing
$2300 shipped will part out for the right price
http://s51.photobucket.com/albums/f3...turbo%20stuff/
h22 109mm stroker kit never used:
90mm ross pistons
Cunningham rods
109mm crank
total seal rings
$1100 plus shipping
http://s51.photobucket.com/albums/f3...20h%20stroker/
Arias h22/ h23 16.5:1 89mm bore pistons
with rings, wrist pins and locks
$550 shipped
h22 bare block
$100 plus shipping
h22 obd2 dizzy and oem coil
$165 shipped
h22 new aftermarket rebuild kit
pistons std size
rod and main bearings std size
thrust washers
head gasket
$25
type s pistons with rings used with low miles
$200 shipped
h23a1 block with h22 water pump, oil pump, oil pan everything use in the picture just no pistons or rods
$200 plus shipping
http://hondamarketplace.com/showthread.php?t=2987140
electric water pump
aluminum ice box
90mm ross pistons
Cunningham rods
109mm crank
total seal rings
$1100 plus shipping
$550 shipped
h22 bare block
$100 plus shipping
$165 shipped
pistons std size
thrust washers
head gasket
$25
$200 shipped
$200 plus shipping
92-96 Prelude Tail Lights with cleared turn signals. $80 obo, PM me if you'd like to see pics.
92-96 Prelude amber front turn signals. $120 obo, I get them in all the time, so PM me and see if I can grab you a set.
Accord Rear Lips, I can also get these easily so hit me up and I'll see if I can grab some. $100 obo
Ractive Cone Air Filter, make me an offer. Got a K&N filter for free so switching to that.
Have a few 4th gen front lips for sale...
Value Sports Sports Under Spoiler SOLD
Aero Magic Under Spoiler SOLD
JP (Aero Magic) Under Spoiler SOLD
Locobanana Front Lip Spoiler $400
IMG_6157 by ManjuGrip, on Flickr
IMG_6163 by ManjuGrip, on Flickr
Value Sports Type 2 Rear Under Spoiler $400
Test Fit by ManjuGrip, on Flickr
Test Fit Profile by ManjuGrip, on Flickr
More pics in my flickr account.
Email is best: ManjuGrip@gmail.com
Thanks for looking
Thanks for looking
Black driver's side door handle in good condition. Some scratches here and there, but still functions properly none the less. Handle isn't cracked nor are there any cracks anywhere else on it. $25 shipped
Driver's side window switches $35 shipped
PM for pics or if interested.
OEM Headlights for 5th gen
Headlights are in decent condition.
Both need to be restored as there is some haze. A 3m restoration kit would do the job well on these. Only one broken tab and that is on the top driver side headlight. I can go ahead and fix it with gorilla glue or if you would rather just do it so you know its been done to your standards that it fine as well. I will throw in an 8000k Hid Kit as well (Bulbs and Ballasts) Price will not change if you wont them or not.
PM me your email or cell phone number for pictures.
Price is $130 Shipped. Con US Only. Anywhere else will be extra.
I have my custom made "Si" rear center taillight for sale. Car was wrecked, but this made it through. It has an insert inside the light that you cant see until you press on the brake, then when it lights up, the only light coming through shows "Si" in the same font as the Honda "Si" symbol of course.
Check out a couple pictures here:
Without brake depressed- -
http://a7.sphotos.ak.fbcdn.net/hphot...70370600_n.jpg
With brake depressed- -
http://a5.sphotos.ak.fbcdn.net/hphot...59150419_n.jpg
Back- -
http://photos-g.ak.fbcdn.net/hphotos...42359762_a.jpg
Back- -
All prices DO NOT include shipping or paypal fees.
92-01 H22 Complete JDM Type S intake in great condition. No filter. $160 OBO
97-01 OEM Pearl white trunk in good condition. $80 OBO
For sale a moroso H22 oil pan with an extra fitting welded in bc I ranexternal oil pump. Can plug that off. Have a small dent in bottom of pan from jack. Looking to get $350 for it. baffled and can hold 5 quarts of oil. I have a twin disc spec clutch with very light usage for sale, has a extra ring gear and surface area. I'm looking to get $650 obo. I have a msd digital 6 box with a hvc coil, all good working order, $350 or obo. I also have an ati dampner for a h22 $250 and i also have a prodrive spool for $350. I also have a set of brian crower turbo cams,new in the package,$350. I also have a full race front facing turbo manifold, heat coated and heat taped.Give me a good offer for these parts, and i will consider these offers.
You can call or text me 203-430-3394, if need pics on the stuff
Still have some parts laying around from my 4th gen build that never happened.
- Fully Built H22 Head. ($1200)
- Crower Springs and Retainers
- Ferrara 1mm Over-sized valves
- Full Port and Polish
- 0 Miles
- Used (About 500 miles) Skunk2 Stg2 Cams (SOLD)
- Used (About 500 miles) 1000cc RC Injectors ($250)
- *NEW* APEXi AFC NEO ($300)
- Stock H22A with all Accessories minus the harness and 150,000 Miles ($500)
- Full set of stock tan leather seats. The fronts are in need of repair. ($250)
- Both front stock Black Leather seats. They show normal wear. ($200)
- 0 Miles
The price is not include shipping and add 3% or gift for paypal.
1) the door panels black leather inserts came off a 96 VTEC in mint condition. Asking $40
2) the camber kits all 4 front and rear for 92-96 prelude. Not sure if it will fit 97-01 prelude. asking $20
3)The front brake pads came off S model, but will fit Si. Not VTEC model. It is the "best" brand offered by advance auto part. Asking $10
Everything will be shipped thru parcel post via USPS or thru UPS ground via UPS with tracking number.
PM me
PM me
neuspeed front strut bar 4th gen prelude $90
http://i31.photobucket.com/albums/c4...e/618a7d17.jpg
FS: H22 euro r manifold modified ready to bolt up come with hondata IMG $450
Complete AC system
This came off my 2000 base prelude
Everything worked fine before taking it apart excepts one thing. (the recirculation motor got messed up. This is on the white box aka the blower motor, you can manually switch if you want recirculation inside or not). After that everything works perfect.
AC compressor 40$
Evap box 50$
AC lines 60$
condenser SOLD
AC compressor mount bracket 30$
Blower motor 40$
Everything for 250$ shipped
AC compressor 40$
Evap box 50$
AC lines 60$
condenser SOLD
Blower motor 40$
