d16a1 swap into 91 dx hatch questions
my buddy is swapping a d16a1 (dohc) out of an 89 integra into his 91 hatch, weve both done a bunch of research on it and everybody seems to have different answers for everything, the car was originally a d15b1 (70hp
) with a 4spd trans, so what is he going to need mounts/axles wise and what will he need regarding the wiring?
any help is greatly appreciated, thanks!
) with a 4spd trans, so what is he going to need mounts/axles wise and what will he need regarding the wiring?any help is greatly appreciated, thanks!
The D16a1 is not a direct swap into an ED(ef) and it will require a lot of custom fabrication skills to even get the motor in. NO stock mounts can just be put on and drop it in there, hope you guys got some fab skills. IMO not worth it just get a jdm dohc zc.
i guess he'll be using a trans out of a crx instead of the one that came on the d16a1, if that helps the situation any
as far as i can remember, i don't think that will work. not sure but i thought you couldn't bolt any of the sohc trannys to that block?
this swap is not a direct swap not even worth the time and money just get a dohc zc
I dont even think a cable si tranny will fit on to it...... you can only use the tranny that came with the d16a1 which is useless
dohdoh420
Jun 20, 2007 09:03 PM
lvzero0
Oct 11, 2005 08:41 AM
RLD
Jun 29, 2004 09:19 AM
idontcare
Nov 28, 2003 07:47 AM
