RPM work. speed odometer doesn't. Why?
Old Nov 3, 2011 | 08:43 PM
koumatae's Avatar
Default RPM work. speed odometer doesn't. Why?
my speed odometer work but works weirdly. the MPH is off about 10mph. so if i go 15 mph, speed odometer show 25mph. if i go 10 mph, speed odometer show 20mph. ect. how can i fix this? has anyone had this problem before.
Old Nov 3, 2011 | 09:42 PM
DirtyDA9's Avatar
Default Re: RPM work. speed odometer doesn't. Why?
The tach works because the tach and speedo get their signals from two completely different places. Have you changed and gearing or drasticly changed tire/wheel size?
Old Nov 4, 2011 | 12:46 AM
koumatae's Avatar
what i change was the whole cluster. i didnt change tire or wheel size. but what do you mean "changed and gearing"? i thought it would be "plug-n-play" but i guess not.
Old Nov 4, 2011 | 04:32 AM
BryanM.'s Avatar
Resident Gearhead
What is the car? (year/make/model)
Which engine?
Is there a CEL? (check engine light)
Answer all of these questions for better help!
Old Nov 4, 2011 | 11:18 AM
DirtyDA9's Avatar
I meant have you changed ANY gearing... What cluster did you swap in?
Old Nov 4, 2011 | 12:55 PM
koumatae's Avatar
i have a 94 Integra RS 2 door (B18B1) with no check engine light on. i also did not change anything on tranny or motor. i bought the cluster from someone on craigslist. i knew it was from an ls/rs dc2 because it redline at 6900 rpm and look exactly like any other cluster from ls/rs dc2. i try to reset the car by pulling out the negative on battery but that didnt work. any suggestion what else i can try? thanks HT
Old Nov 4, 2011 | 04:07 PM
DirtyDA9's Avatar
Originally Posted by mcvtec
I don't understand what gearing or tire size has to do with the tach not working.
Read the title again "RPM works, speedometer doesn't.", rpm (as in tach) works. He is asking why his speedo is off, not about a non functioning tach.
His tach DOES WORK, it's the speedo that's off by 10mph. Drastically changing tire size, or gearing affects it.
Old Nov 5, 2011 | 07:00 AM
BryanM.'s Avatar
Resident Gearhead
My apologies, I somehow got very mixed up or mis-read.
I agree with what you are saying.
Old Nov 5, 2011 | 09:44 AM
DirtyDA9's Avatar
Lol It's all good I figured you were, I was wondering why you kept saying tach haha
Old Nov 5, 2011 | 10:42 AM
frankenghia's Avatar
did you have this problem before you changed the cluster?
Old Nov 5, 2011 | 04:18 PM
koumatae's Avatar
the gas meter didnt work so thats why i put the new cluster in. before that, the speed odometer work normally but now since i put another cluster in, the speed odometer is off and gas work. thanks HT for all your help.
Adriano
Transmission & Drivetrain
Jul 11, 2012 02:28 PM
91akira
Mar 6, 2009 12:45 PM
dso
May 19, 2005 05:14 PM
See Are Ex
Dec 6, 2004 01:12 PM
integra-modder
Nov 5, 2002 11:52 AM
