B18b1 swap in 92' Honda Civic Si (Engine kicking & frustrating)
Old Nov 3, 2011 | 08:15 PM
Arturo Gatti's Avatar
Icon3 B18b1 swap in 92' Honda Civic Si (Engine kicking & frustrating)
I currently have a b18b1 in my 92' Honda Civic Si. It seems that the engine is bogging and feels like it's not getting juice as I hold the pedal at a steady RPM & Speed. I have no idea what is going on & would like some assistance ASAP plz!! Thank You
Old Nov 5, 2011 | 06:49 AM
Gunmetal_B20_Hatch's Avatar
Default Re: B18b1 swap in 92' Honda Civic Si (Engine kicking & frustrating)
CEL?
Old Nov 6, 2011 | 09:18 AM
ktsciv93's Avatar
Originally Posted by Gunmetal_B20_Hatch
CEL?
^^^ timing?
Old Nov 7, 2011 | 07:32 PM
Siriuswerks
Guest
Posts: n/a
Firing order needs to be checked, Timing, and with a noid light (harbor freight) injectors.
if all is good check fuel pressure.
Old Nov 9, 2011 | 12:12 AM
10psiLsEf2's Avatar
check your tps sensor (throttle position sensor)
Get a Meter.
Start car'
Stick a saftey pin in the middle wire.
Connect red lead to saftey pin
Black wire to ground
Lossen tps sensor
Move around sensor
Untill you get .5 volts at idle
And 4.5 at wide open throttle
Old Nov 9, 2011 | 12:15 AM
10psiLsEf2's Avatar
IM SORRY DONT START THE CAR!
just turn on key to accessories
im a little tipsy
TravisCadello
Sep 11, 2008 08:41 AM
92egSnatch
Mar 28, 2008 09:52 AM
1998_Lude
Jan 9, 2006 04:07 PM
