A/C question from SOHC to DOHC
Old Nov 3, 2011 | 06:37 PM
guessohw's Avatar
Default A/C question from SOHC to DOHC
I currently have all of the A/C components from my 96 and 98 d16 engines. The question I have is will those parts work on a 99 EM1 with a B16A? What would need to be done in order for everything to work or would it be just be bolt everything in place? Thanks
Old Nov 3, 2011 | 07:37 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: A/C question from SOHC to DOHC
Keep it simple and retain your stock a/c setup. You can use it all with any B16/B18 setup by simply using a new a/c bracket from either a dohc vtec del sol, or any 97-01 honda crv....they allow you to bolt up your stock d series compressor to a b series block
Old Nov 4, 2011 | 12:19 PM
kungpowchicken's Avatar
Sorry if this is not relievent, can you do the same with power steering?
Old Nov 4, 2011 | 02:06 PM
B18CivicEJ8's Avatar
Power Steering: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-retaining-power-steering-ek-b-series-swap-1822781/
HondamanXxX
10
Sep 8, 2007 06:25 PM
jerrym
48
Sep 7, 2007 04:32 PM
t57b18
Apr 11, 2006 06:52 AM
WuShu
May 11, 2001 08:41 PM
