shaky steering wheel
cant seem to figure out what is wrong with my hatchie the steering wheel shakes when i get up to about 45mph i ve changed the rack n pinion, upper adjustable control arms, and the ball joints, cant seem to figure out the problem and i am goin through tires every month so if anybody has any suggestions please let me know
If it happens only when braking it is likely brake rotors, however from what you describe I would say a combination of two things. Bad alignment (causing tire wear) and tires out of balance (causes the vibration). Is it possible that since you are going through tires often that you only pay to have them mounted and not balanced as well? That would be your easy fix. Tire balance and alignment
i had the alignment done when i changed the rack, and the wheels were balanced when i bought another set of tires, the tires are not wearin unevenly they go bald almost perfectly even across the whole tire, i was thinken if maybe it could be possibly the wheel bearings but i am not sure
no it doesnt whine but i get a loud creaking sound from the driver side when i make turns or even when i am parked and turn the wheel it makes the same sound, but it seems like somethin is loose and the wheels tend to pull to one side when i drive over cracks or uneven pavement but i ve double checked everythng to make sure nothin was loose
bsmith100
Mar 10, 2010 01:10 PM
mikeunreal2
Jun 3, 2007 12:12 PM
rice_classic
34
Aug 29, 2005 07:46 PM
Seann
Jul 29, 2001 02:22 PM
