FS: Rcae Parts look inside everything you need
PR3-2 head done by Alaniz with super tech (1mm) over size exaust valves and super tech stock size intake valves Super tech springs and titanium retainers
$1,400
B16 Victor X intake manifold
$250
GSR Victor X Intake Manifold Square Ported
$250
Blox 70 mm trottle body
$150
ITR cams
$250
ITR red valve cover
$100
AEM cam gears
$100
CROWER Billet turbo rods for GSR
$500
Gsr crank
$100
Moroso oil pan new
$225
ATI Super Damper Street pulley
$250
TILTON twin disc clutch
$ 1,100
Clutch Master twin disk clutch
$925
M&H slicks 26x10 x15 brand new
$300
MSD Digital 6 Plus
$250
B16/TYPE R Hondata Intake Manifold Gasket NEW
$40
B16/TYPE R Hondata Intake Manifold Gasket USED
$30
JDM EG Cluster
$150
Eagle Rods for LS OR B20 USED
$250
Parr Rods for GSR USED
$500 for 5 or $450 for 4
JE 81MM Pistons Low Compression one is pitted
$200
Golden Eagle Fuel Rail RED with Gauge no fittings
$145
BOSCH 044 Fuel Pumnp
$100
Walbro 255LPH USED
$60
GSR Shift Linkage
$125
Stock EG rear Lower Control Arms with energy bushing
$60
Peakboost Top Mount Turbo Manifold T4 flange 44mm vband wastegate flange
$$850
2000 Civic SI ECU P2T
$100
Greddy Intercoler will support 1000 HP
$250
Bogart Flystars
15x8 fronts with Mickey Thompson 24.5x9x13
15x3.5 with MH Racemasters 25x4x15
$950 for all 4 with tires
RC 1200 CC Injectors
$240
Bosch 750cc Injectors
$225
Chuck
310-977-1201
$1,400
$250
$250
$150
ITR cams
$250
ITR red valve cover
$100
AEM cam gears
$100
$500
Gsr crank
$100
Moroso oil pan new
$225
$250
$ 1,100
$925
$300
MSD Digital 6 Plus
$250
$40
$30
JDM EG Cluster
$150
$250
$200
$145
$100
Walbro 255LPH USED
$60
GSR Shift Linkage
$125
$60
$$850
$100
$250
Bogart Flystars
$240
$225
Chuck
310-977-1201
