ef b18b swap mount bolts
What bolts are you referring to?
You do realize that the swap mounts are made to fit in the factory locations, right? Thus utilizing the factory mount to chassis hardware...
I used slightly longer bolts for the rear mount to the cross member bec. the innovative mount was a bit thicker than the stamped steel oe mount.
Other than that I used all the same bolts.
p3t3rxp4n
Jul 8, 2012 06:10 PM
