6262 gsr built
Hey HT just got my block back and started to put it back together.
so thought i should make a thread
** * * * * * *Block: gsr*
ERL sleeves 81mm*
Cp pistons 11:1 com
Cp upgraded pins
Crower billet rods*
Acl race bearings
** * * * * * *Head gsr
Skunk2 *pro valve train*
Mazworx turbo cams
Golden eagle head studs
Oem Honda head gasket
** * * * * Turbo *Pte 6262 81ar*
3in Intercooler piping Tial bov*
4in Intercooler*
Forward facing manifold*
Tial 44mm wastegate
Victor x intake manifold 70mm tb
** * * * * * Fuel*
Walbro intake to a 044
8an feed 6an return
Aem fuel rail automotive regulator
1600 injectors*
** * * * *Computer*
Aem ems*
Aem boost solenoid*
http://a1.sphotos.ak.fbcdn.net/hphot...66779961_n.jpg
ERL sleeves 81mm*
Cp pistons 11:1 com
Cp upgraded pins
Crower billet rods*
Acl race bearings
Mazworx turbo cams
4in Intercooler*
Tial 44mm wastegate
** * * * * * Fuel*
8an feed 6an return
1600 injectors*
** * * * *Computer*
Aem ems*
Aem boost solenoid*
im on a 6265 build sleeved gsr and made 532/360 on pump gas.. gotta get a bigger intercooler, 3" intercooler pipe and a twin disk then take it to get tuned on c16.. im sure just on pump you will be higer then that.. looks great so far again
Looking through some of these threads, and I see several people running the front facing mounted setups. How is the air filtering done on these setups, if at all? I know most are probably track only machines that just run a screen, but is there a way of running an air filter that doesn't look like a hard-on poking out the front of the car?
thanks guys my computer took a **** so i can only go here on my phone and cant upload pics, but i want from a 6262 to a 6766 so the car can make more
so i can run truestreet down here
Yes I used the Mazworx turbo cam on my old stock sleeves set up but, and they worked grate the car was just a simple piston and rod set, 9:1 gsr and on Crome with a sc61 63 ar made 410 on 16 psi with s2 tuners 2, then switch the cams to the Mazworx cams and made one pull on the dyno and made 429 on the same tune just by switching cams, tuned the car for cams and made 440 so the car picked up 30hp just from cams all on pump gas, then I switched the turbo to a 6262 83 ar and aem and the car made 450 on 15 psi on pump gas and 550 on 20 psi on 112 gas,the set up lasted almost 4 years of everday beating and finlly cracked a sleeve, haven't tryed the pro1s yet
So guys got the car tuned and stuff dint really take all the way cause we had distributor problems, on 23 psi the car made 650 @ 8000 rpm, the found out the car had a bad head that was worped, but put a new head and got the t1 trigger kit just waiting on the m&w box and gonna tune it again should make over 800 no problem.
