inner tie rod install question
Old Nov 3, 2011 | 02:25 PM
andybmuzik's Avatar
Default inner tie rod install question
I have to replace a inner tie rod on my del sol tommorow..I know there is a special tool you can rent..but my question is..will this be a simple fix or is there any specific things you need to know/do?
Thanks
Old Nov 3, 2011 | 02:33 PM
LoLoCivic's Avatar
Default Re: inner tie rod install question
after that tie rod is replaced you will need an alignment or close to one because your toe of your ties will be off and it will eat your tires.
Old Nov 3, 2011 | 02:55 PM
thenext's Avatar
20% cooler
Thanks
The inner tie rod is threaded on to the rack gear. There is a special tool for it but you don't need it. I just used a monkey wrench. Mark where the jam nut on the outer tie rod is with some white out or something so it will be easier to align.
Old Nov 3, 2011 | 03:37 PM
24TEN's Avatar
PHANTOM MENACE
^Exactly what I did, then went straight in for an alignment. No special tools needed.
project-boosteD
Sep 14, 2008 09:26 AM
VTECIntegra9
Suspension & Brakes
Aug 14, 2008 02:02 PM
streetsold6teeny8
Jul 4, 2008 11:33 AM
rasinhell
May 3, 2005 09:23 PM
Timmah!!
Jul 21, 2003 03:46 PM
