can i use this piping for turbo manifolds
Old Nov 3, 2011 | 10:09 AM
hoochhenry's Avatar
Default can i use this piping for turbo manifolds
in need of some help can i use these bends for turbo manifolds Carbon Steel S235 Pipe Fitting ,1 1/4 think its 3 mm thick mybe more heres some pictures of it
also argon gas can be used when tig welding and whats the best filler rod to use ?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Nov 3, 2011 | 01:21 PM
hoochhenry's Avatar
Default Re: can i use this piping for turbo manifolds
any input lads would be great
Old Nov 3, 2011 | 02:10 PM
RadekSkylark's Avatar
These can be used. Stainless steel is better, but for budget or first build you can definetly use them. I made my first manifold from them, used 1 1/2" with 3mm wall.
Good luck
Old Nov 3, 2011 | 02:34 PM
hoochhenry's Avatar
Good luck
cheers also i guess this piping has to be back purged too ?
Old Nov 3, 2011 | 02:38 PM
No, you don't need to backpurge this, this is mild steel, which has no sugaring as far as I know.
Good luck!
Old Nov 3, 2011 | 02:50 PM
hoochhenry's Avatar
Good luck!
sounds good thanks again good input great help
Justin Olson
Welding / Fabrication
32
Jul 7, 2008 11:18 AM
DXK Eg
29
Aug 26, 2006 08:31 PM
weraider30
Jul 19, 2003 12:55 PM
