Will a 1989 hf chassis harness fit in a 1989 dx
Old Nov 2, 2011 | 08:17 PM
1991crx16's Avatar
Default Will a 1989 hf chassis harness fit in a 1989 dx
Just as the title states will a 1989 honda crx hf chassis harness fit a 1989 honda crx dx without any major problems?
Old Nov 4, 2011 | 11:47 AM
1991crx16's Avatar
Default Re: Will a 1989 hf chassis harness fit in a 1989 dx
Still trying to figure this all out completely. I have a dx with an obd1 d15b vtec. The wiring harness "tuck" was done very poorly so I decided to replace everything. I ordered a new chassis harness which I thought was a dx, and when I got it I found out it was for an hf. The hf harness I got is a complete harness with the fuse boxes, the seperate dash harness and everything, just not the harness for the rear of the car. I was planning on having a custom engine harness made so would I be able to put the hf harness in and have an engine harness made to connect to that?
Old Nov 4, 2011 | 12:00 PM
JDpower's Avatar
This will only work if you have an HF engine harness aswell and the rear tailight harness. I did this on my DX to convert to MPFI the only problem I ran into with the rear tailight harness was it wouldn't plug into my hatch harness because it was for an Si and had more wires. Idk if that would be a problem if you have a hatch from a Dx though.
ByonSho
Feb 2, 2010 01:13 PM
crx89backedout
Jan 14, 2010 03:36 AM
shackler
Mar 22, 2007 07:21 PM
d16z6crx
Jul 5, 2004 09:25 PM
FAST AS
10
Mar 23, 2004 12:17 AM
