Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
>>>Gold Heat Barrier Rolls & Exhaust Wraps<<< HARDPARKED.com
Old Nov 2, 2011 | 03:19 PM
HardParkedCom's Avatar
Default >>>Gold Heat Barrier Rolls & Exhaust Wraps<<< HARDPARKED.com
EMAIL ME FOR SPECIAL HONDA-TECH PRICING !
Email:sales@hardPARKED.com
Heat Barrier
Reflect-A-GOLD
A high performance reflector born in the aerospace industry for use in extreme temperature swing environments, this state-of-the-art polymer is extremely light weight and capable of handling continual operating temperatures up to 850 F.
Highly effective material for firewalls, fuel cells, engine covers, under hoods, engine compartment, bulk heads, seat bottoms – anything or area that needs protection from heat.
  • Reflects up to 80% of radiant heat
  • Virtually NO clearance needed
  • Fire resistant adhesive side rated up to 325˚F
  • Self-adhesive backing for easy install and removal
sizes:
  • 12"x12" sheet
  • 12"x24" sheet
  • 24"x24" sheet
  • 1-1/2"x15' roll
  • 1-1/2"x30' roll
  • 2"x15' roll
  • 2"x30' roll
Cool-Tape
Cool-Tape offers a flexible, easy to apply and ultra light weight solution to reflect heat and ideal for wrapping wiring, cables, hoses, fuel lines and covering seams. Made of one mil aluminized material bonded to woven fiberglass, Cool-Tape has a super strong self-adhesive backing capable of protecting up to 2000°F radiant heat and available in two different widths and three different lengths.
  • Withstands 2000°F radiant heat
  • Flexible and easy to apply
  • Strong self-adhesive backing
  • Secure & seal panels, seal air boxes & more
sizes:
  • 1-1/2" x 15' roll
  • 1-1/2" x 30' roll
  • 2" x 60' roll (Cool Tape Plus)
Reflect-A-Cool
Reflect-A-Cool, constructed of fiberglass material backed with a layer of aluminized reflective foil to handle direct continuous temperature of 400°F has many uses such as covering firewalls, marine engine compartments, RVs, in the tub of a racecar where typical mechanical fasteners cannot be used and has many industrial uses.
  • Withstands 2000°F of radiant heat
  • Self adhesive for easy installation
  • Can be easily trimmed to size
sizes:
  • 12" x 12"
  • 12" x 24"
  • 24" x 24"
  • 36" x 48'
Exhaust Wraps
Titanium Exhaust Wrap with LR Technology
Titanium exhaust wrap, with LR Technology, is made from pulverized lava rock and stranded into a fiber material and woven into a proprietary weave. Titanium wrap is engineered to be stronger than most wraps on the market today. It has the ability to handle higher heat for improved thermal performance, durability, and reliability – and with a cool carbon fiber look!
  • Withstands 1800˚F direct/2500˚F intermittent heat
  • Promotes increased flow for improved performance
  • High resistance to abrasions, chemical & oil spills and abrasions
  • Reduces temperature & vibration breakdown
  • Extremely pliable for a tight and secure wrap
  • Pre-wetting roll not necessary for wrapping
  • Hi-tech carbon fiber look
sizes:
  • 1" wide x 15' roll
  • 2" wide x 15' roll
  • 2" wide x 25' roll
  • 1" wide x 50' roll
  • 2" wide x 50' roll
  • 2" wide x 100' roll
Exhaust Wrap - Black
Exhaust Wrap - Tan
Wrapping headers and down pipes is an important first step in controlling unwanted underhood radiant heat. Keeping exhaust gases hotter within the exhaust system helps in decreasing exhaust density and increases exhaust flow. This improves exhaust scavenging resulting in cooler air intake temperatures for an improvement in performance and a gain in horsepower.
Design Engineering stainless steel Locking Ties are the perfect way to fasten exhaust wrap for a easy, clean and professional installation.
  • Reduce under hood temperatures a realistic 50%
  • Improves horsepower
  • Withstands 1200°F direct/2000°F radiant
  • Only exhaust wrap with installation guide lines
  • Added durability and heat retention
black sizes:
  • 1" wide x 100' roll
tan sizes:
  • 6" wide x 100' roll
  • 8" wide x 100' roll
Exhaust / Header Wrap Kits
Everything you need for a professional installation in one kit. Includes 2 roll of 2" x 50' exhaust wrap, 1 can HT Silicone Coating, Stainless Steel Locking Ties (eight 8" and four 14") are included.
The header wrap kit is enough for any set of V8 headers. The Header Wrap Kit will wrap from the top of the header where it bolts to the heads all the way down to the collector. Exhaust Wrap Kits save you time and money.
sizes:
  • Black Wrap w/ Black HT Silicone Coating
  • Tan Wrap w/ White HT Silicone Coating
  • Tan Wrap w/ Aluminum HT Silicone Coating
Old Nov 2, 2011 | 03:36 PM
Default Re: >>>Gold Heat Barrier Rolls & Exhaust Wraps<<< HARDPARKED.com
ttt
Old Nov 2, 2011 | 04:09 PM
v-tec just kicked in yo!
Old Nov 2, 2011 | 07:16 PM
bump
Old Nov 2, 2011 | 07:52 PM
Old Nov 2, 2011 | 11:10 PM
bump
Old Nov 3, 2011 | 12:28 PM
bump
Old Nov 3, 2011 | 02:49 PM
bump
Old Nov 3, 2011 | 03:48 PM
bump
Old Nov 3, 2011 | 03:55 PM
ttt
Old Nov 3, 2011 | 04:43 PM
bump
Old Nov 3, 2011 | 05:20 PM
bump
Old Nov 3, 2011 | 07:44 PM
ttt
Old Nov 3, 2011 | 08:53 PM
bump
Old Nov 3, 2011 | 10:01 PM
ttt
Old Nov 4, 2011 | 10:57 AM
bump
Old Nov 4, 2011 | 12:12 PM
bump
Old Nov 4, 2011 | 02:50 PM
bump
Old Nov 4, 2011 | 03:45 PM
bump
Old Nov 4, 2011 | 04:03 PM
bump
Old Nov 4, 2011 | 04:29 PM
ttt
Old Nov 5, 2011 | 12:39 AM
ttt
Old Nov 5, 2011 | 10:02 AM
bump
Old Nov 5, 2011 | 01:02 PM
ttt
Old Nov 6, 2011 | 01:59 PM
bump
