golden eagle sleeved block built
i am the first and only owner of this block...there are NO stripped bolts anywhere on the motor... buyer will be provided with receipt form golden eagle... (786)
236-6751
b20 sleeve block $1700 OBO
Golden eagle 84mm hd sleeves with o ring deck
9:1 arias pistons 84mm
Eagle 2000 big bolt rods
Acl race main barings
Acl race rod barings
Acl thrust washers
Ls crankshaft
Micro polish crankshaft
Golden eagle sandwich plate
OEM timing belt
OEM type r water pump
OEM type r oil pump
Gsr oil pan with -10 for oil return
Golden eagle head studs
when block was new and first put together!
236-6751
Acl thrust washers
Ls crankshaft
OEM timing belt
OEM type r oil pump
boosted1996
Apr 29, 2017 10:48 PM
