head milled question
Old Nov 1, 2011 | 10:42 PM
longhairbro17's Avatar
Default head milled question
i have a 91 crx dx with the everything stock. i am planning on doing the mpfi swap so i picked up everything needed for that as well as a extra si head with everything on it. now i got the head milled .040" and i understand that i have to retard the timing by about 4 degrees, from doing my research i believe its 1 degree; .012"milled. now here is my question, if i put a a6 cam which from what ive read retards the timing by 4.75 degrees(correct me if im wrong), how much do i need to retard my cam timing to avoid detonation. ive looked at a compression calculator and i should be at 10.19:1. thank you for any help
Old Nov 2, 2011 | 07:08 AM
jlicrx's Avatar
Default Re: head milled question
on a SOHC D-series engine, milling the head 0.040" will only change the cam timing by slightly over 1 degree (1.0132*)
Old Nov 2, 2011 | 08:18 PM
Anybody else?
Old Nov 3, 2011 | 06:44 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Originally Posted by longhairbro17
Anybody else?
What do you want to know? The the math and answer was already given to you by "jlicrx". The camshaft grind is probably off that much... If you are that worried about it get an adjustable cam gear so you can advance it and put it back to factory.
If you want to read on exactly how he got the answer then look at this...
http://hondaswap.com/attachments/471...camdegrees.pdf
Your camshaft will already be retarded from the milling... and you don't have enough compression to worry about detonation. A Honda engine is efficient enough to run 10:1 on 87... unless you have super crappy gas then try it and listen for detonation... If you have some then go from there.
Old Nov 3, 2011 | 09:39 AM
EF4lyf3's Avatar
I love learning new things! Thanks for the post N3va3vasatisfied!!!
#Leo#
May 20, 2010 11:17 PM
JDMs1eeper
Aug 19, 2003 10:27 PM
rambler
Dec 23, 2002 06:54 AM
Rhetoric
Sep 11, 2002 10:02 PM
MackSpeed-616
Apr 13, 2002 07:56 AM
