found a crack on my turbo manifold yay!!!
Old Nov 1, 2011 | 09:42 PM
jdmcivic2fast's Avatar
Default found a crack on my turbo manifold yay!!!
LOL, my ramhorn manifold finally gave up lol, found a crack line around the welds on where the wastegate runner meets the collector. Whats the right way to go about fixing this crack line? Do I just put new welds over it or what do I do?
Old Nov 1, 2011 | 10:55 PM
AdReNaLiN's Avatar
Default Re: found a crack on my turbo manifold yay!!!
Grind as much of the old weld out (around the crack) as you can... then weld over it.
Make sure you get the metal nice and clean.
Old Nov 1, 2011 | 11:39 PM
FredC's Avatar
Considering its in the wastegate runner, you'll want to remove the wastegate and use a drum sander or something that can clean the carbon from the inside of the tube first. Then i would recommend cleaning the outside of the tube with a wire wheel or soemthing similar. Then you could even use a liquid (acetone or even soap and water) to wipe the surface down and then weld it back up
Old Nov 2, 2011 | 06:08 AM
turbojeesx's Avatar
Drill a hole on either end of the crack, bevel, clean and tig weld.
Old Nov 2, 2011 | 03:49 PM
weiRtech's Avatar
OG Fabricator
put the wastegate flange right on the collector, weld inside and out.
Old Nov 7, 2011 | 12:44 PM
SpeedwayCoating's Avatar
x2
Old Nov 8, 2011 | 02:41 PM
HickamHatch's Avatar
Here's something from another message board
Originally Posted by onefstek
I had a customer bring in a turbo manifold that had a crack in one of the runners. This will show step by step on how your properly fix a cracked weld.
Reason this manifold cracked is because the flange was warped and when it was bolted to the engine it put too much stress on the weld.
Cracked runner
1. Cut the cracked runner all the way around.
2. Bevel the two sides so you can get a deep penetration and good strong weld
3. Make a root pass weld, starting with the bottom of the runner. This will help keep the flange as flat as possible. Also notice the back purge hose, that will give you a nice weld on the outside as well as the inside.
4. Make the fill pass and let the manifold cool down while is still bolted to the welding plate so it will keep the flange as flat as possible.
This was a customers log manifold that was on a nissan. No name on it so I don't know who made it. Besides, that is not whats important.
Stefan
gaundy22
Mar 17, 2016 08:10 PM
AutoLab
Jun 30, 2007 07:15 PM
.RTErnie
Welding / Fabrication
12
Dec 21, 2005 02:30 AM
StolenTeg
Jan 6, 2005 04:13 PM
dtec
Aug 10, 2003 02:25 PM
