F20b questions
Old Nov 1, 2011 | 03:43 PM
andraomark's Avatar
Default F20b questions
dose anyone knows if the shift linkage , motor mounts , and all the axles the same or differents from a f23a1 tranny and a lsd f20b tranny
Old Nov 1, 2011 | 05:16 PM
liveinspired's Avatar
Default Re: F20b questions
i believe that they all match up shouldnt have any problem doing a simple swap. not sure about the shift linkage i thought they were cables. what year car?
Old Nov 1, 2011 | 05:52 PM
andraomark's Avatar
ok cool the car is a 2001 accord coupe
Old Nov 1, 2011 | 06:29 PM
yea im sure everything bolts right up do more research to make sure...
someone confirm this
Old Nov 1, 2011 | 08:31 PM
nus_dogg's Avatar
As for shift linkage, they're all the same. No need to waste money. I'm running an F20B T2T4 LSD trans on my H22 right now and still running my stock Accord linkage.
For the tranny mount, as long as it's a 94-97 5spd tranny mount, you're fine. Accord or Prelude one will work. Has to be a 5spd tranny mount though.
For axles, make sure the driverside axle is an Accord if you're running an Accord intermediate shaft. If it's a Prelude driverside axle that you plan on running, make sure you have a Prelude intermediate shaft. Passenger side won't matter if it's from a Lude or Accord IIRC.
Torx
Mar 26, 2012 07:48 PM
JDM H22
Oct 10, 2007 03:09 PM
pinecone
Oct 1, 2007 07:56 PM
prelude1911
May 29, 2007 08:09 AM
JDMCertified
Mar 29, 2007 09:47 AM
