up and down idle 95 d15b7 cel 41 after timingbelt/headgasket/waterpump change
Old Oct 31, 2011 | 03:23 PM
Jason P's Avatar
Default up and down idle 95 d15b7 cel 41 after timingbelt/headgasket/waterpump change
i changed my timing belt, head gasket, and waterpump on a 1995 d15b7 sohc non vtec. a cel code comes up 41. the car idles high and low inconsistently and it sounds like a misfire from the exhaust. the distributor is on and the firing order is correct. all the plugs are in the right place and the 02 sensor seems fine. when i did the timing for the timing belt tdc on the bottom block was right on the line but the head was off by a hair but either way i moved the cam gear it was still off. so im assumin the timing is fine. anyone have any ideas?
Old Oct 31, 2011 | 04:08 PM
grumblemarc's Avatar
The Grumpiest
Default Re: up and down idle 95 d15b7 cel 41 after timingbelt/headgasket/waterpump change
Air in cooling system possibly. Did you bleed it properly?
Old Oct 31, 2011 | 04:29 PM
Former User's Avatar
This^
Also check whether you accidentally broke the heater element power or ground wire for the O2 sensor.
Old Oct 31, 2011 | 06:37 PM
Jason P's Avatar
Originally Posted by RonJ@HT
This^
you know both of you guys are right i appreciate the help. i did not bleed the coolant system and when i took the header off the 02 hit the ground pretty hard. so i will check those tomorrow. im gonna double check if i have any vaccumm leaks too.
Old Nov 2, 2011 | 02:20 PM
Jason P's Avatar
up and down idle was fixed on account i forgot to tightin the top manifold bolts. fail.
still cel for 02 time to check the wires.
jz2518
Jul 8, 2013 07:09 AM
tech410
24
Jun 7, 2012 08:10 PM
coilz
Apr 23, 2008 03:51 PM
Import_spoon
Apr 21, 2008 08:55 PM
mc
Oct 26, 2004 04:30 AM
