b20 in eg Cold start issues
So i have a 92 Si hatch, i dropped my b20b in out from my 93 hatch. Issue im having now is starting it. When the motor is cold i have troube starting it. It will turn over for a few seconds and then die out. But after a few time of that, i can turn her over (lol). And any time after that, i can turn off the car and crank her over with no issue. I replaced the tps sensor (broke while pulling the motor out), injectors cleaned, replace ignition coil, cap, etc...and im getting a code 16 form the ecu (fuel injectors). Battery is good and have a new starter. And im replacing the MAP sensor this weekend. And my ebrake light wont turn off now. Any help on this would be noice! thanks
which sucks but i'll try to source one and test it. my fuel pump does work, at least i can here it when i turn the key to on. thanks!
Jturpen569
Oct 11, 2016 02:49 PM
runghostrun
18
Jan 22, 2010 05:06 AM
Jimmy
Jul 10, 2003 08:52 AM
