Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Help!!! 2005 Acura TL wont start!
Old Oct 31, 2011 | 11:38 AM
amoseley21's Avatar
Icon3 Help!!! 2005 Acura TL wont start!
Hi,
I have a 2005 Acura TL 3.2 that wont start. I drove the car to work and it worked fine. When i was going to lunch my car wouldnt start. It turned over, but wouldnt actually start. Listened for the fuel pump "whine", but no noise. Replaced the fuel pump thinking this was the problem...still nothing. Checked the starter coils, and they are putting out around 6.4 - 6.7 volts...should be enough to fire up the car, but still nothing.
Thoughts? Any help is appreciated!
Old Nov 4, 2011 | 07:57 PM
spoolinfool's Avatar
Default Re: Help!!! 2005 Acura TL wont start!
Did u even check the battery first?
Old Nov 25, 2011 | 09:04 PM
Simplypinoy's Avatar
Or possibly spark?
Old Dec 24, 2011 | 03:25 PM
projectTeG's Avatar
use your spare. your key might be bad and not engaging the ecu
Old Jan 4, 2012 | 09:31 PM
wilp99's Avatar
i agree sounds like the immob is tripped for some reason.
Old Jan 5, 2012 | 08:27 AM
lsd96teg's Avatar
its a shot in the dark, but is it possible the fuel pump has a relay or fuse that may be blown?
Old Jan 5, 2012 | 10:56 PM
slomofo's Avatar
GDD Member
Fuel pump has no fuse but there is a relay for it. The relay is called a main relay and is under your dashboard on the driver's side near the fuse box. It's a big square relay with a brown bottom.
The relay looks just like this.
If you grab a test light you can actually probe the pins on the relay to see if power is going into the relay and then probe the pin that goes to the fuel pump. That's probably the quickest way to test it.
I'm almost positive your relay has a brown bottom but be forewarned that there's some that have white bottoms. Here's a couple more for reference:
Old Jul 11, 2012 | 03:51 PM
prowheelie92's Avatar
hello im having a similar problem i feel my relays vibrating when trying to start the car. the car still dosent start can the relay create this problem? thanks
Rick Overton
33
Aug 6, 2015 07:47 PM
LiftNRace
Jun 1, 2013 01:22 PM
ANNiHiLATORS
May 27, 2011 07:43 PM
miguel329
Jan 5, 2009 06:36 PM
Lsweez
Jun 28, 2007 10:08 PM
