95 civic d15/y8 head. weird noise when idle but stops when clutch is in?? HELP
So this started kinda recent sometime when I get start car up from a cold start SOMETIMES will get a weird screeching till I give lil gas then goes away. Then while idle will sometimes have a weird noise an as I push the clutch in it changes??
Any ideas? I searched an couldn't find anything with exact same problems
Screeching - check for a loose or glazed drive belt.
Noise that goes away when clutch pedal is pushed down - this is typically the sign of a bad main bearing (e.g., input shaft bearing) in the transmission.
Ok than you a friend of mine was saying prob throwout bearing? Also what exactly is a glazed belt? Thanx for ur input!
a glazed belt is a belt that is shiny from slipping "glazed". this will cause the belt to not grip the pulley any more and precede to slip more and more unntil it overheats and pops
C-West Civic
Sep 10, 2013 04:58 AM
Full Race A6
Sep 7, 2004 02:12 PM
