VA 500whp k20a2 6 speed 2000 si
Old Oct 31, 2011 | 10:19 AM
aj906115's Avatar
Default 500whp k20a2 6 speed 2000 si
Alex
located in richmond virginia
phone-516-426-4438 call or txt
trade-yes
price drop-make me an offer $$ talks
description- 2000 em1 si with a complete k20a2 swap with 6 speed trans.First and for most I want to say this thing is scary fast, Itl spin in 4th gear at like 85mph, its not too loud either has a nice deep tone to it ,It has a godspeed 60-1 turbo brand new not even 1000 miles on it motor build also has 1000 miles on it also both were done at the same time. The is tuned on k rpo by charmcity motorsports , boost by gear is set up makes it a bit more managalbe in the lower gears.I will provide dyno sheet for new onwner if wanted.I am manily looking for a sale ,Heres the breakdown....
MOTOR-
2003 k20a2 swap with je pistons and eagle rods cometic headgasket ,obx turbo manifold,hybrid racing fuel rail, id1000 injectors, god speed 60-1 turbo (17psi), custom powder coated one piece chargepipes, 44mm wastegate, 50mm bov,charm city wire tuck, push lock vaccume fittings, rbc intake manifold, hasport swap harness, 3" turbo back custom exhaust, 6speed trans, walbro 255, new fuel regulator and -6an fittings and lines, kpro(purchaced new from ktuned llc for 1200$) same side intercooler (hidden behind bumper).k pro has boost by gear set up
INTERIOR-
carpet needs cleaning but all interior is there with del sol seats up front,stock em1 si seats in the rear carbon around cluster with aem uego wideband and true boost mounted in frog eye style cluster
SUSPENSION/EXTERIOR
drope zone sleeve coilovers dropzone struts in front / brand new kyb gr2's in the rear
eibach front camber kit, usdm itr 5 lug conversion /wt 97 spec itr wheels (good tires)
8k hid's yellow fogs
The bad-
2nd gear pops out needs new blocker ring (basically if you dont hold it in gear it will pop out )
heater core is lopped out
rear bumper has a crack in it
fenders are black need paint ( there jdm fenders with the corner lights)
speedo doesent work I have a k20r harness to add in with sale
I will post much better pics tommorow!
josemig007
Sep 24, 2011 11:05 PM
icantthinkofaname
May 11, 2009 09:53 AM
boostaholic
Jun 28, 2004 07:18 PM
